Elemental designs 12 inch subwoofer $13.50 ($25.53 Shipped)
Old Nov 27, 2007 | 02:36 PM
semaj3708's Avatar
FEELS GOOD TO BE GANGSTA
For those of you on a budget.
http://www.edesignaudio.com/edv2/pro...roducts_id=183
Info...
Qts : .375
Qes : 0.49
Qms : 1.506
Fs : 25 Hz
Re : 1.8
Vas : 157 L
MMS : 90g
BL : 7.2 Tm
SPL : 89.1 dB
SD : 510 M^2
Xmax : 9.1 MM
Magnet Width : 5.25"
Cutout : 11.00"
Mounting Depth : 5.00"
Total Height : 5.60"
Displacement : .04 cF
Outside Diameter : 12.00"
Box Size : 1.5cF Sealed / 2.0cF Vented
Power Handling : 200w
Informational / Release Thread Here
http://www.icixsound.com/vb/showthread.php?t=28522
HT Subwoofer Design Thread:
http://www.icixsound.com/vb/showthread.php?t=39744
Old Nov 28, 2007 | 12:31 PM
LILMAN's Avatar
Are they good subs? That looks too good to be true.
Old Nov 28, 2007 | 12:50 PM
slickrick's Avatar
if it sounds too good to be true (no pun intended)then it probably is...
Old Nov 28, 2007 | 09:57 PM
filtor1's Avatar
Info...
Qts : .375
Qes : 0.49
Qms : 1.506
Fs : 25 Hz
Re : 1.8
Vas : 157 L
MMS : 90g
BL : 7.2 Tm
SPL : 89.1 dB
SD : 510 M^2
Xmax : 9.1 MM
Cutout : 11.00"
These subs require as much if not more air space than any other 12. Very low levels of capable excursion, 9.1MM. Only handle 200 watts, I assume that is recommended maximum power handling. They are relatively inefficient at 89.1w/m meaning they will have well below average output at their rated power.
The only thing this sub has going for it is the mounting depth and the price. Maybe a good buy as an upgraded sub for a computer, but outside of that, you get what you pay for. I would personally save up for something that will actually do what I need it too, sound good and get loud.
VQ'ed
69
Aug 27, 2020 12:29 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
