AVN5500 Backup Camera Help
Old Jan 4, 2008 | 12:49 PM
MaximaInCT203's Avatar
schemes on chicks in his max.
Ok so i have the AVN5500 with the bec106 backup camera (back eye camera) installed on a 2002 maxima. I have everything hooked up and it works fine. Im trying to figure out if it is possible to get the unit to switch to the camera when i put the car in reverse. Is there some cable that i need to splice/connect to? Thanks in advance for your input folks!
~Myles~
Old Jan 4, 2008 | 03:40 PM
DcMaN's Avatar
there should be a reverse wire on the brain. Im not sure on the exact location of the wire but im sure you can find it at the taillights by testing each wire you will find the reverse signal.
Old Jan 4, 2008 | 06:23 PM
when u say "on the brain" are you referring to the clip end that connects into the head unit? are you saying that there is a wire within the camera wiring that needs to be spliced into the wire that triggers the reverse lights? thanks in advance
Old Jan 5, 2008 | 08:41 AM
DcMaN's Avatar
coming from the headunit there should be a Green wire, which is your reverse signal. You need to connect that Green wire to the Reverse wire located at the tail lights.
Old Jan 6, 2008 | 03:29 PM
hey the camera works flawlessly! Thanks a TON man. Greatly appreciated!
Old Jan 7, 2008 | 08:32 AM
burnurass's Avatar
Damn wish I saw this earlier...
There is a reverse wire in the driverside kick panel. green wire. =P
Looks like you got it working though so that's good.
Just curious...where did you mount yours?
I mounted mine here:
Old Mar 24, 2008 | 09:18 PM
Deckdout2's Avatar
Play with my balls
So ummmmm.........which of the 38,000 green wires is it?
Old Mar 25, 2008 | 04:17 AM
mendon99's Avatar
tastey wheat
test light/dmm would come in handy here.
Old Mar 25, 2008 | 05:57 AM
burnurass's Avatar
lol bish!!! call up don, he will look it up for you...FOR A FEE. =P
I think it's green/pink...lol though don't quote me on that.
Old Mar 25, 2008 | 05:59 AM
Deckdout2's Avatar
Play with my balls
mmmm, you're right it would. or of the many people that knows exactly where it is, could just tell me too.
Old Mar 25, 2008 | 06:02 AM
Deckdout2's Avatar
Play with my balls
I can't believe after searching this forum all lastnight, this was the only thread that came close to answering this question. Like no one here has installed a navi and had this question come up or something. blah...
Old Mar 25, 2008 | 06:54 AM
burnurass's Avatar
I think most people just tap the reverse wire from the tailights.
Old Mar 25, 2008 | 08:58 AM
Deckdout2's Avatar
Play with my balls
I would seriously prefer not to run the reverse signal all the way back there. i'm still looking with the hopes that Don will answer here before I find it.
Old Jun 1, 2008 | 07:32 PM
imported_D_Roc's Avatar
i'm having the same problem so i have to hook the wire from the HU to the + or - led of the reverse light
wyobbagy
Jan 3, 2023 12:03 PM
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
James92SE
Oct 8, 2015 04:57 PM
