Distribution block necessary?
Old Jan 10, 2008 | 10:37 AM
sicivic89's Avatar
Quick wiring question. I have a self-powered 8" Bazooka tube along with the 4-channel Kenwood amp to install in my Max. How would I need to run the power and ground cables? I already have a 8-gauge wiring kit laying around. Would I need to buy a distribution block setup to run both?
Also, a side question: I have a set of aftermarket speaker for the fronts, but not the rears. If I install an aftermarket headunit, and power front speakers off of the amp, can I somehow run the rears BOSE off of the headunit until I can afford to buy some new rear speakers?
Old Jan 10, 2008 | 11:56 AM
sicivic89's Avatar
oops.....wrong audio forum.......mods please move to the other audio/video forum. Thx
Old Jan 10, 2008 | 12:09 PM
BLACKonBLACK98's Avatar
Former Vendor
you will need a distro block to run multilpe power wires. you should be able to run the rears off the hu with an adapter.
Old Jan 10, 2008 | 07:00 PM
djfrestyl's Avatar
Suspension Yoda
And you don't need a dist block for ground. Just put the two wires (with ring terminals) on the same grounding bolt.
Old Jan 16, 2008 | 09:54 AM
phenryiv1's Avatar
Mod her. Ate her.
Buy my fused D-block...$25 shipped!
Old Jan 16, 2008 | 11:09 AM
BigPete's Avatar
Incognito
I wouldnt recomend using 8gauge on a distro block.. but if you must go for it. Run some 0/4g then drop it down to 4/8.
shilov
Feb 19, 2024 09:40 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
