4th gen Max 2-way active!
This is a build log for my 1998 Maxima.
The components to my system include.
Head Unit
Pioneer Premier 880 PRS
Front Stage
LPG 25NFA 1" Tweets Powered by a Kicker 100.2 with Seas Prestige CA18RNX 7" Mids Powered by two channels of a Kicker 850.4
Substage
2 Sundown 10" SD-1's powered by the other two channels of the Kicker 850.4 bridged to 4 ohms
Deadening
2 Rolls Raamat BXT and 6 Yards of Ensolite which will be focused on the front doors and the trunk
Day 1
After a bunch of planning buying talking and BS'ing about the system we finally got it started by deadning the trunk.
First we stripped to the bare bones
Prep/clean the trunk for a good stick
The stock deadning
The Goods
Head Unit
Front Stage
Substage
Deadening
Day 1
The stock deadning
The Goods
Always a great phrase to see
Michael(my roommate) working in the trunk
Our High Performance cutting board
Me getting under the rear deck
Rear deck complete and Rear fill FTW!!! j/k
The trunk is dead
This is all we had left of the entire roll when we got finished
*UPDATE* January 1st 2008
Got the Head Unit installed and the RCA's ran today!
The Stock Setup
Got Everything thing tore down. Had a problem with getting the hazard light switch unplugged so we just put the whole piece on the top of the dash and left it connected
Random Pic...
Had to custom fit a piece in the gap between the bottom of the unit and the pocket. The Scoshe kit provided a new pocket that only made it look worse
Remains of the piece that we hacked
Added a hole in the back of a pocket to run the Ipod connector into a sweet little spot.
Completed! Sorry about the quality of some of the pics, my digicam can be very finicky
New headunit is very nice and actually a lot more graphical then I expected. Under a quick listen the stock speakers sound a wee bit cleaner. I will be spending the entire night reading the owners manual lol. This is definitely a very involved headunit, but extremely nice
Some deadning on the panel to stiffen it up a bit
Install the Woofa!
Woofa Installed!
The completed door back together!
Its been a long process but very rewarding. Now time time to ask alot of questions! I'll post them in a new post in a sec. Sadly the Ipod connector doesn't work but it will get fixed/replaced. Time to start EQ and TA and set the gains =)
ya i definately need to head over to one. just give me a holla. what day do yal normally hold the meets?
http://forums.maxima.org/showthread.php?t=552568
im running these for subs
they will be getttin ruffly 400rms
they are low wattage subs. if u want more info i can get ya a link.
im building the box to get everything out of them i can pretty much.
the sundown Icons are some excellent subs if u are looking for some more powerful ones. i will probably wont upgrade my subs for some time depending on how good those work. also got some more work today on the box would of got some more done but a lil thing called the superbowl got in the way.
i wish the shop was mine but its a good friend of mine and he pays attention to details to a 32nd of an inch. the box is very percise but if i build another one it will be done different. just got to get the carpet on it and the rest of the wiring done hopefully can get it all done this weekend. crosses fingers
and thanks for yalls input
ya it is the speaker wire that im goin to run through the box so i can wire the subs to 4ohms cuz they are 8ohm drivers. the wire is just there to see what size hole i would have to have. should be done this weekend and dont have to work tomorrow
ya i should of done that before i installed them but if i hear any noise im probably goin to scrap the box and make another one cuz with what i designed i thought i could still get to my spare but thats a negative. so if i redisgn it i got to shirnk some things.
nice box dude. you should come out to the SQL meet me and my buddy are holding. basically it's a friendly contest. we each get score sheets and go around listening to all those who enter. and then we tally up the points in the end.
Those mids are 3.2 ish inches deep correct? how much clearence do you think you have from the back of the magnet to the window when its rolled down? I ask because I am going to try to squeeze something that is 3.5 inches deep
well my baffles are 2" inches think and with this the door panel doenst exactly fit back properly there is like an 1/8" gap i would say at the bottom of the door. if i recall they were like 3 & 1/8" deep im think 3.5 will be cuttin it pretty close. i cant recall how much space i had but i know it was enough sry. if i would guess i would say there was maybe a .25 to a .5 of an inch behind there maybe more.
