The BOSE Radio/Speaker Replacement thread
Your headphone OUTPUT from the Nexus only has left and right. (4 wires total)
Your SLC4 INPUT has 4 channels. Total of 8 wires.
Split the headphone output wires. You need to make 8 from 4. Connect the left output to both front and rear input on the left, and connect the right input to both front and rear input on the right. Naturally, positives connect to positives and negatives connect to negatives.
My bad again. I thought the headphone output has only 2 wires. By next week I should be able to assemble the nexus 7. Waiting for just one part.
Thanks again.
Got aftermarket speakers with Bose HU. Replaced Bose HU with avh p-4300 and now no sound. I'm guessing I no longer need the Pac oem-1 being that everything is aftermarket. What do I need to check/do in order to get sound?
I got the Metra wiring harness part# 70-7550 for 99 Nissan Maxima Bose system and I have the following questions:
1. Cable # 9, per your harness guide in the first page, The larger harness is missing Shield Wire Ground (ground wire runs with signal cables(+ and -) for front BOSE amplifiers to shield their signal). Do I need this cable?
2. I also see the Shield Wire Ground (Cable # 11). Should I connect these shield wires to the Ground? or can I leave these open?
3. Cable # 12- Amp On Signal Wire (turns on all 4 BOSE amplifiers) - I believe this is not a power cable for the Amp. Am I right?
In my case ( using the Nexus 7 as the stereo HU) how do I trigger this signal?
Pls advise.
Thanks for your great forum again.
Hello Again,
Pls advise.
Pls advise.
2. Similar to #1, if a standard ground, connect together, then ground to chassis.
3. Your nexus does not have this. Recommend just tapping off of your red ACC wire.
Here is the wiring diagram from the first page:
Larger Harness:
10_8 ___4_2
9_7_6_5_3_1
1 = Front Left -
2 = Front Left +
9 = Shield Wire Ground (ground wire runs with signal cables(+ and -) for front BOSE amplifiers to shield their signal)
10 = ACC/Ignition (the red wire)
Smaller Harness:
16_______12
15_14_13_11
11 = Shield Wire Ground (ground wire runs with signal cables(+ and -) for rear BOSE amplifiers to shield their signal)
12 = Amp On Signal Wire (turns on all 4 BOSE amplifiers)
For Item #1 & 2.
Cable # 9 & 10 are the Shield Wire Ground. Can this be considered as the common ground for the chassis? Since the Cable #9 missing in my Metra harness, can I leave the cable slot alone.
For Item # 3
Yes, I'm planning to tap the red wire for the tablet power. But what about Cable # 12- Amp On Signal Wire? Can I leave this alone? I was under the assumption that if we leave the cable alone, the Amp will not power up.
Pls advise.
Thanks again.
Thanks for your quick reply.
Larger Harness:
10_8 ___4_2
9_7_6_5_3_1
1 = Front Left -
2 = Front Left +
Smaller Harness:
16_______12
15_14_13_11
For Item #1 & 2.
For Item # 3
Pls advise.
Thanks again.
Larger Harness:
10_8 ___4_2
9_7_6_5_3_1
1 = Front Left -
2 = Front Left +
Smaller Harness:
16_______12
15_14_13_11
For Item #1 & 2.
For Item # 3
Pls advise.
Thanks again.
Red wire should ALSO power the amp remote turn-on.
When I connected the tablet, the sound was good, but I forgot to start the car and see if I get the same quality sound. I had to connect the Power (12+Red Wire) to the Amp On signal (Cable 12 on your diagram). Pls let me know if there is a better way to do this.
Thanks again.
Just wanted to give an update on my project. I was able to connect my Google Nexus 7 to the factory stereo harness successfully. Thank you. Without your help I wouldn't have accomplished this. Now I need to work on the tablet mount using the factory stereo facia.
Thanks again.
Thanks again.
Glad it all works. Pics!!
teejay1786
hello i was wondering if anyone could tell me why my bose system in my 2001 maxima se keeps cutting out ive tried everything and ive even tried the pac-roem nis2 and still it cuts out im not dumb and have installed many stereos before im lost can anyone help me i have a massive ground so....?
bose cuts out
the way i wired it is exactly how it looks color for color no wires are loose or amiss im very specific and also have two other vehicles with complete systems hooked up i have all the blue wires to one spot and i have a massive ground and ive hooked it up every way low level + only then high level + only still it cuts out
STILL not enough fcking info. Please be clear and concise. Use punctuation. Help us help you.
When specifically does it cut out? When you raise the volume? When you go over bumps? Randomly?
This HU has 5v preouts. You don't need the PAC ROEM-NIS2. You can wire it directly using a Metra 70-7551. Rewire it - properly this time, using good solid connections - and report back.
would this fit my 202 maxima BOSE system?
http://www.crutchfield.com/S-cfmdp9j...ml#details-tab
are they any good the frequency response is 45 - 25k Hz, so i'm not sure if it would be better than factory.
also forget price for now (if i were to buy i'd be getting a deal)
would the speakers have to be used sans crossover?
^^ They will physically fit and should be used with the included crossovers.
"Good" is what sounds good to you. Some people like heavy bass. Some people like clear highs. Recommend listening to them prior to purchasing.
well you can't install normal speakers but, these are 4ohm so i guess i'm just being negative/doubtful.
i do have a concern though, the odd bit is each speaker supposedly has it's own amp, as far as the factory system. i wonder if it's soldered to the speaker or inline with the wires/cables. how does that work out?
Here on the forums in the 5th gen section i could have swore i read that each speaker has it's own amp. that's why it's so different form other systems and that's why you can install just any head unit and you need a special adapter. also that is the reason why it uses low ohm speakers and why you can't use normal 8 ohm speakers like most cars.
Close, but not quite.
It is 4th gen Bose system that has a small amp at each speaker, not 5th gen. In the 4th gen it makes replacing the speakers much easier. In the 5th gen, there is a centralized speaker amp under the rear deck which is wired to each speaker.
Both 4th and 5th gen run at 2ohm. It is the Bose system that dictates the impedance. If you had a Maxima without Bose, then it would be running at 8ohm.
I didn't use the DVD Drive to mount the tablet. Instead, I mounted the tablet on top of the compartment(Tray) using duct tape. I used the compartment because its already got the push lock mechanism. So, in locked tray position, the tablet is completely inside and when I want to take it out, I can simply push the tray to unlock it. It's very simple and the duct tape holds the stereo facia well with the compartment/tray.
Here are couple of pictures of my new dash.
I have also kept a 4 Port USB hub inside the dash so that I can connect multiple USB disks /devices to the tablet. It's working great so far. I wanted to keep the USB hub inside the center console. But I didn't get time to do that. I have also ordered a Push Button switch to turn on/off the Amplifier.
Thanks again for all your support.
Is this your finished product? In order to access the USB hub and optical drive, you have to remove the fascia panel which has the tablet mounted to it?
Additionally, your finishing material on the visible part of the dash piece is seemingly...black duct tape? Or black electrical tape? And is the finishing piece made of a wood of some sort??
No offense, but this looks terrible.
- Dash piece should be made of some sort of plastic. Sheets of ABS plastic are very cheap and easy to work with.
- Dash piece should be painted.
- Trim panel should be securely mounted without a "remove to access" feature. You clearly have spare room underneath the tablet. Put the optical tray there, not behind. And flush mount some USB ports on an access panel.
I'm glad it works, but your 'finishing' needs some further thought.
Actually, no, its not a finished product. I have to get the dash sticker to put on top of the fascia. I put the tape on top of the fascia because I didn;t get the same color fascia. My trim color is black and don;t want to use it. So I ordered a used fascia from ebay, but I got only the wood trim color.
Now I'm not using the optical drive to hold the tablet. I made a holder on the back of the fascia and it's mounted on the compartment. So when I push the compartment/tray open, the entire fascia on which the tablet is mounted comes out and I can take the tablet out easily. I know it's a dirty work, but I will definitely try to implement your suggestions soon.
Thanks again!
Cool, glad its all mocked up properly. Now it just requires that level of finesse to finish it up - and sounds like you're well on your way for that.
Definitely post finished pics!
