The BOSE Radio/Speaker Replacement thread
Old Apr 7, 2016 | 05:53 PM
  #1161
djfrestyl's Avatar
Suspension Yoda
You can, with some creative wiring
Old Jun 14, 2016 | 08:10 PM
  #1162
maximized98's Avatar
Addicted to the Org
I have a couple of questions. I am going to replace the bose head unit in my 02. I already have the 70-7551
1. I have been reading that I still might need a LOC to go along with the 7551. Is this true?
2. Would it be beneficial to go ahead and get one, or would it not make any difference?
Some people have experienced low volume levels after swapping to an aftermarket HU
Old Jun 15, 2016 | 06:01 AM
  #1163
djfrestyl's Avatar
Suspension Yoda
It depends completely on the preout voltage of the HU you pick.
1. Yes
2. It can be used even if you don't need one. So if you go ahead and get one and use it regardless, it causes no harm - just a few extra bucks spent unnecessarily.
Old Jun 15, 2016 | 06:14 AM
  #1164
Addicted to the Org
Thank you. What LOC would you recommend?
1. Yes
Old Jun 15, 2016 | 06:37 AM
  #1165
djfrestyl's Avatar
Suspension Yoda
Scosche SLC4 does the trick.
Old Jun 15, 2016 | 07:32 AM
  #1166
Addicted to the Org
I have never used one before. So this gets wired between the aftermarket HU and the 7551??
I was looking at pictures of the SLC-4 and I'm a little confused
Old Jun 15, 2016 | 07:35 AM
  #1167
djfrestyl's Avatar
Suspension Yoda
Head Unit -> Speaker Level Outputs -> Speaker level inputs on LOC -> RCA outputs on LOC -> RCA inputs on 70-7551 -> Car harness
Old Jun 15, 2016 | 07:58 AM
  #1168
Addicted to the Org
You are the man
Old Jan 7, 2018 | 06:11 PM
  #1169
jtbask11's Avatar
Hey guys, hope this is the right place to ask.
I'm looking to get an aux/BT input to my car (2000 max with Bose+sub) and it seems like the best way to do that is to replace the head unit. I've done a handful of car audio stuff so it shouldn't be too hard but I had a question.
What inputs does the amp have? Just front and rear, or front, rear, and dedicated sub? I can get a cheap 4 channel output head unit for $60 but one with a dedicated sub output is much more.
Old Jan 15, 2018 | 03:55 PM
  #1170
jtbask11's Avatar
Does anybody know the answer to my previous post? I tried searching but I couldn't find much. Thanks
Old Jan 17, 2018 | 11:37 PM
  #1171
ptatohed's Avatar
Licensed to Spell
jt, how about one of those blue tooth kits for OEM stereos?
https://www.crutchfield.com/g_356850...jn&subid=43737
Old Jan 20, 2018 | 09:43 AM
  #1172
jtbask11's Avatar
Good idea, but the one there is $170. I can buy an aftermarket 4 channel head unit with bluetooth for $60. I bought the car for $600 so I'd like to keep this as cheap as possible.
Do I need just a regular 4 channel output or do I need 4 channel and subwoofer?
Old Feb 12, 2018 | 05:21 PM
  #1173
Karim's Avatar
I have a headunit without preamp outputs I want to install and the 7551 harness.
Can I make this work?
  #1174
Karim's Avatar
There is no sub in the car.
Old Feb 14, 2018 | 04:01 PM
  #1175
jtbask11's Avatar
There is a subwoofer in the BOSE sound system, it's in the rear behind the seats.
As for your question with the 7551 harness you can cut off the RCA connectors and wire the speaker level outputs from your head unit to them. I'd recommend soldering and heat shrink, just as with any electrical connection.
The solution I went with was to buy a cheap ($60) head unit with 4 channel RCA outputs and the Crutchfield kit for the car. It came with the 7551 harness, a faceplate, and a speaker to line level converter. I followed all the directions and it actually sounds pretty good, having bluetooth in the car is nice.
Answering my original question, the subwoofer is tied with the rear speakers, so only a 4 channel output is needed. My sub was actually not functioning, but bypassing the crossover fixed it.
Old Feb 15, 2018 | 12:43 PM
  #1176
Karim's Avatar
That's what I ended up doing. I'm actually midway through the install. The HU works great but the 7417 dash kit doesn't seem to work for this..
Old Feb 16, 2018 | 09:43 PM
  #1177
Nissanfinatic's Avatar
Subs
I have the Bose system in my 2014, I want to install two subwoofers I need a little more kick. I have been told if you have a Bose system its impossible. Is that true and if it is I am o.k. with that but I need some base with my music its driving me nuts.
Old Feb 16, 2018 | 11:17 PM
  #1178
Karim's Avatar
https://maxima.org/forums/7th-genera...tallation.html
Old Dec 2, 2021 | 08:37 PM
  #1179
A35bippupr's Avatar
09 Max Bose/NoNav/Amber Screen Headunit Replace
Hey guys, im going to install double din touchscreen in my 7th gen but keep the stock bose speaker and amps since i like how they sound. Just want to confirm my parts list to make sure it sounds exactly like stock.
-Metra 70-7553 harness
-A good LOC
-Double din dash kit to put the New Unit where the 6disc cd changer is
Does that sound right?
Thank you all
Old Dec 3, 2021 | 04:55 AM
  #1180
silvermaxd's Avatar
-A good LOC
Thank you all
Is that what Crutchfield has listed for your car?
Old Dec 3, 2021 | 05:07 AM
  #1181
A35bippupr's Avatar
Yes and No. Lol
I added the line out converter because of what i read on other posts about upgrading the headunit. Apparently if you connect your New headunit Preamp outs directly to the rca inputs on the 70-7553 harness, either you will get noise or low volume. I saw that it was recommended to use the Line Converter between the headunits speaker wires (not the preouts) and the 70-7553 rcainputs, to get a cleaner louder signal.
However this was for older gen maximas (5th and 6th) with Bose. Im not sure if it applies to the 7th gen. Im just going to buy a very good active LOC on crutchfield. If i end up not needing it ill return it.
Still would be good to know from anyone else if i actually need it or not, or confirm my parts list
Old Feb 6, 2022 | 03:33 PM
  #1182
KP11520's Avatar
I have a few 4th Gen Bose questions......
FM still works, but sounds HORRIBLE! Antenna is rebuilt. Do the heads lose stability or has what radio stations put out degraded substantially?
CD player doesn't work anymore. But used to sound quite good for a Nissan offering.
How do you all know when the speakers/(amps) are trashed (tweeters too) and the whole system needs a forklift upgrade?
I'd be quite happy with it performing like new and invest the money in other max upgrades for reliability and comfort.
Thanks for any help!
Old May 9, 2022 | 02:01 AM
  #1183
denise1968's Avatar
Bose is just a royal pain in my BUTT. lol
Old Aug 13, 2023 | 01:24 AM
  #1184
djrobshow73's Avatar
Bose premium speaker amp issues, right rear.
I'm having bass issues with the speaker and a short in the amp or speaker. If I tap on the speaker, the bass comes back on. Is there a repair schematic for that Bose premuim powered speaker I can refer to, in order to pull it out and and repair what's shorting out or needing soldering.
6spd4dsc
May 9, 2022 12:30 PM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
melteye
May 16, 2016 12:02 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
