HU problem...
Old Oct 2, 2008 | 11:34 PM
JY05's Avatar
HU problem...
installed everything from the harness to the antenna adapter and grounded the wire.. the tuner (radio) works just fine.. but the PROBLEM is for some reason the CD player and the AUX front in doesnt work .. and by that i mean no sound comes out but the radio works .. any suggestions?
i had a factory bose audio player which was taken out and replaced with the Sony CDX-GT110 CD player and still have the original amp for the 95' Maxima.. it seems to read the CD and plays just fine but no sound i wonder why
Old Oct 3, 2008 | 01:23 PM
mrjamaica98mx's Avatar
WHAT HARNESS ARE U USING?
Old Oct 3, 2008 | 01:57 PM
kpr10is's Avatar
You wired your power antenna output from the radio (blue) to the factory amp turn on wire in the harness (blue/white). Wire blue to blue and blue/white to blue/white. Or if your radio has no amp turn on output, wire the blue/white to switched power (red).
Old Oct 3, 2008 | 03:02 PM
JY05's Avatar
mrjamaica98mx:
i bought a harness from best buy in the install bay which i think was called GXL something harness..
kpr10is:
yeah i just checked the wires and there was no amp turn on wire.. the rest of the wires was in correct color order.. but one question wouldn't wiring the blue/white into the power wire cause the amp to stay on even though the radio is off? since i've heard that wire has to do something with the ignition switch or something.. and plus wouldn't that rigging cause a drain in my battery?
Old Oct 3, 2008 | 04:41 PM
kpr10is's Avatar
Yes, the amp would stay on when the radio was off but ignition was on.
No it wouldn't drain your battery. It is switched power, the amp would turn off when you take the key out.
Old Oct 3, 2008 | 09:16 PM
JY05's Avatar
thanks man.. ill try to figure it out.. if not, ill take a picture of it and see what everyone has to say about the problem
Old Oct 3, 2008 | 09:35 PM
BLACKonBLACK98's Avatar
Former Vendor
agreed. you probably have the antenna wire to the amp turn on so your amp is only on when you use the radio.
use the amp turn on from the hu harness (blue/white) instead.
Old Oct 3, 2008 | 09:42 PM
kpr10is's Avatar
Its a Sony CDX-GT110. It doesn't even play mp3 cd's, let alone have any preouts or an amp turn-on output. lolz.
OP, tap the blue/white on the harness you bought from best buy into the red wire. All will work fine.
Old Oct 3, 2008 | 09:46 PM
Former Vendor
yikes.
yeah what he said.
Old Oct 4, 2008 | 07:08 PM
JY05's Avatar
thanks to kpr10is and BLACKonBLACK98.. i finally got it to work.. its not the best HU, but its a start lol thanks again
nadir_s
Apr 15, 2003 09:51 PM
Cabowabo
Dec 11, 2002 02:02 PM
nadir_s
Jul 23, 2002 01:11 PM
lorddeceiver
Aug 6, 2001 06:23 PM
