remote starter STICKING!?!
Old Oct 18, 2008 | 02:18 PM
webjohn's Avatar
my remote starter is sticking when i click it to start my car. what do you think is the problem, any solutions?
thanks
Old Oct 18, 2008 | 02:27 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Care to elaborate with details? What vehicle? What system? What EXACTLY is it doing?
Old Oct 18, 2008 | 02:50 PM
JSMax's Avatar
Sold
too much on the remote.
Old Oct 18, 2008 | 05:37 PM
webjohn's Avatar
its a 2000 quest, with an audiovox elvatoc aps2k4saw remote start system. i believe it was installed by the dealer. it hasn't been used in a couple of years (like 3 or 4), so i now decided to putit back into action. i went ahead and put a fresh battery in (13 dollars worth) and when i went to use the remote it didnt work so i went under the steering wheel and jiggled around the box and it started opening and closing with the remote. then i tryed starting it, it went to start and started but it didnt stop starting it kept going for about 2 to 3 seconds and then it stoped and the car stayed on.
Old Oct 18, 2008 | 05:39 PM
mendon99's Avatar
tastey wheat
so it just continues cranking without starting? My first guess is that the tach needs to be reprogrammed... if it was connected that is.
Where are you located? you'll probably need to take it to someone who knows what they're doing.
Old Oct 18, 2008 | 05:48 PM
webjohn's Avatar
no, it cranks and starts, but continues to crank after staring for a couple seconds, then it stops cranking and stays on.
funny u should mention where im located, im in south florida right now, but i moved from providence rhode island and drove down in this car.
Old Oct 18, 2008 | 05:53 PM
webjohn's Avatar
its not the remote D*C% weed
Old Oct 18, 2008 | 07:20 PM
Pearl96Max's Avatar
Definitely sounds like the tach. New battery = needs to be relearned.
Old Oct 18, 2008 | 08:36 PM
webjohn's Avatar
so let me see if i understand. the remote start system uses the tach to shut off the starter when it reaches a certain rpm?
is it too complicated as for you to explain how to reset the "tach". i have a little know how but a little explanation would be helpful.
Old Oct 18, 2008 | 08:38 PM
Pearl96Max's Avatar
You would have to do a search for the manual of that particular model. I dont touch em, so I have no clue as to their process.
Old Oct 19, 2008 | 06:08 AM
mendon99's Avatar
tastey wheat
Audiovox.com I would think. I don't deal with audiovox either.. good luck
maxima297
Sep 30, 2015 03:32 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
msellas
Sep 23, 2015 09:16 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
