Ipod adaptor for Bose system
Old Dec 26, 2008 | 10:04 AM
jagged777's Avatar
I just bought a maxima 03, which has a bose system and wanted to know where i can find an ipod adaptor to connect with my ipod and use it in my car.
Any suggestion?
Old Dec 28, 2008 | 11:56 AM
Emaximus's Avatar
Crutchfield.com
Old Dec 29, 2008 | 10:43 AM
AEMAXIMA01's Avatar
if you have the 6cd in-dash changer you can't use the usa spec ipod adapter.
Old Dec 29, 2008 | 09:28 PM
djfrestyl's Avatar
Suspension Yoda
If you're going to spend the $130 or whatever it is for the iPod ->Bose adapter, might as spend a little bit more and swap out your entire head unit. The additional cost is marginal, and the increase in sound quality (and versatility) will be exponential.
Old Dec 30, 2008 | 06:35 AM
AEMAXIMA01's Avatar
depends on what his tastes are. I chose the usa spec bc i'd rather keep the stock look. but yes, aftermarket does sound better than bose.
Old Dec 30, 2008 | 06:47 AM
snowboi1289's Avatar
The best/cheapest way to do it, it just get that tape adaptor that comes from a portable cd player, or an mp3 player, and goes to the tape, I have one, but I dont know what its called. Its good for when your car doesnt have a cd player or you want to listen to your mp3 player and your car has a tape player.
Old Dec 30, 2008 | 07:02 AM
Puppetmaster's Avatar
I think people have had decent success with the Harman Kardon Drive n Play or whatever it's called.
I just gave up on all those things and swapped HUs to one with iPod capabilities.
Old Dec 30, 2008 | 07:20 AM
AEMAXIMA01's Avatar
as long as you have a 00 or 01 the usa spec will work. i have had no problems with mine. hk drive'n'play works well too, i believe soonerfan uses it (or at least used to).
Old Dec 30, 2008 | 07:25 AM
perkman87's Avatar
I have the tape. Its magical.
Old Dec 30, 2008 | 10:33 AM
AEMAXIMA01's Avatar
tape adapter FTL!
Old Dec 30, 2008 | 04:40 PM
The tape adaptor thing is good for most cars, like my sisters white Chrysler, because it doesnt have a CD player, the sound system(speakers) are basiclly screw, I made some custom temp. mounts in the front to mount 2 normal circle speakers, in the oval speaker spot.
Right now, I have a Stereo that has the aux. input, so right now, I just hook up a computer speaker wire, and thats it, I have nice sound, coming from my Ipod, to the system.
Old Jan 5, 2009 | 10:57 PM
em_aych's Avatar
Originally Posted by AEMAXIMA01
tape adapter FTL!
exactly what i was thinking. sound quality on the tape adapters are ehhh.
Old Jan 15, 2009 | 08:06 PM
saxguyck's Avatar
sooooo... i have an 05 max with the bose+6cd... and a tape player. all i need now is the iPod attachment. From what i read is that this thing doesn't work?
http://www.usaspec.com/ipod_product_sheets/pa11-nis.pdf
page 3 says it should work until the 06 max. anyone try this on a newer max with the bose?
Old Jan 15, 2009 | 08:07 PM
saxguyck's Avatar
p.s. the tape thing sucks.. ended up getting an fm transmitter. no wires, better sound quality but the signal goes in and out.
Old Jan 18, 2009 | 09:50 PM
rollin-on-dubs's Avatar
Why and the heck did Nissan put a cassette player in an 05 car? I have the 05 and i cant believe they would do that. Who uses cassettes anymore?????
Old Jan 21, 2009 | 12:56 PM
AEMAXIMA01's Avatar
Is it an in-dash 6cd changer or external? If it's external, it should work, if not, it more than likely won't.
Old Jan 25, 2009 | 06:37 PM
saxguyck's Avatar
its an in dash changer. so i guess ill stick with the iPod gateway
Old Jan 25, 2009 | 11:17 PM
eric_holmes's Avatar
+1
I'm about to buy an Ipod and just get the OEM adapter that Nissan sells from the dealer. I also have the Bose system with in-dash changer so I assume that is my only option.
Old Jan 26, 2009 | 08:35 AM
Holty's Avatar
Originally Posted by eric_holmes
+1
is this something the dealer installs for you? how does it connect?
Old Jan 26, 2009 | 01:55 PM
The dealer can install it, and I am sure they will be happy to charge an extra $200 to do the install. It connects to the back of your radio. I plan to run the cables inside my middle console and run it up to the arm rest.
Old Jan 26, 2009 | 08:16 PM
djfrestyl's Avatar
Suspension Yoda
This can be self installed by anyone who knows how to use a screwdriver.
Old Jan 27, 2009 | 06:55 PM
Yeah, thats what I plan on doing.
Old Sep 2, 2009 | 02:49 AM
OG Max4th's Avatar
You are my hero
I just bought a Harman Kardon plug and play, I have a 97 Max with Bose systems, I could not find an(aux in) to connect. Please help me!!
Old Sep 2, 2009 | 03:15 AM
maxima365's Avatar
way to bump a 8 month old dead topic
magiconthetire
Oct 26, 2015 09:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
