fixed the squekey window
Old Feb 10, 2009 | 09:24 PM
maximal01's Avatar
Ok, since this problem has gotten worse with the colder weather and it was finally warm enough outside to see the problem was the window track not the regulator, i decided to tackle it. I don’t think it has a right up so here is my very first. So please go easy I searched and searched and found nothing to help.
The problem- squeaky window, window appearing to move off track about a 1/4 inch maybe less
What you will need- I used 1 Phillips head, a flat head, and wd-40(works but grease will work better)
Step 1- remove door panel as if to replace speakers, mine was on the driver side door
http://www.nicoclub.com/articles.php?id=157798
Step 2- my car had plastic with tar around the edges, carefully remove it, mine did not puncture but if it does I guess duct tape will fix it.
Step 3- get a beer (if you’re of age, if not a root beer)
Step 4- locate the track, it should be in the center of the door
Step 5- spray the lube () on one side of the track, then switch I went from the top side a better angle
Step 6- plug your switches in
Step 7- work the window up and down, if squeak is still present repeat 5-6.
Step 8- victory dance
Now my widow is on track and will update if anything happens
Old Feb 10, 2009 | 11:11 PM
AscendantMax's Avatar
that's good that you fixed your window problems...but umm...how is this related to audio and electronics?
Old Feb 11, 2009 | 06:15 AM
maximal01's Avatar
its an automatic widow... theres electric in the door.... it seemed like the place to put it lol
Old Feb 11, 2009 | 11:58 AM
true, but that's more in the lines of mechanical topic.
Old Feb 17, 2009 | 02:55 PM
thegreat1dev's Avatar
this is the funniest post i've ever seen. but good work homie
Old Feb 18, 2009 | 06:07 AM
hardincah's Avatar
Good info mine squeeks but I thought it was the weatherstriping sliding on the window, I will check into this, this weekend when I do some other repairs.
I do agree I would have posted elsewhere, maybe in general max discussion, or 5th gen, or in a DIY thread somewhere, but at least you got the info out here.
Good write-up
Old Feb 18, 2009 | 06:23 AM
maximal01's Avatar
ha thanks im just trying to help, did anyone do any thing showing where a good ground is for an amp? ill post some pics where i put mine at
Old Feb 26, 2009 | 01:13 PM
FlipCpt45's Avatar
use the rear center seat bracket bolt. sand off the paint of course.
Old Feb 26, 2009 | 01:29 PM
try to ground it directly to the chassis if possible. i grounded my amps in the spare tire well. the seat bolt will work, but those bolts are often coated in locktite etc, and will increase eletrical resistance...so i don't really recommend it.
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
pears
Sep 18, 2015 05:25 AM
