Preamp passthrough issue...
Old Feb 26, 2009 | 07:44 PM
MadMaxSE-L's Avatar
Doggah Bite...
I finally got my 2nd TC2000 a few days ago, and went to install it today. Install went as normal; sub in, wiring in, last XA4000 in. Got everything bolted up fine but when I went to hook up the last amp, I noticed it was no where near as loud as it was with 1 sub in there
I did some messing around, and when I unhooked the RCA cables from the 2nd amp, the 1st sub got louder. Since I only have 3 sets of RCAs(Tweeters/Mids/Subs), I am running the sub RCA's from the 9887 to one Eclipse XA4000(1st sub amp), and then I am using another set of RCAs to run from the preamp output on the 1st XA4000 to the RCA inputs on the 2nd XA4000(2nd sub amp). It seems as though the signal is getting split when I hook up the 2nd set somehow, and I am loosing a ton of output.
I don't think the outputs should be labled "preamp outputs" if all it is is an internal splitter. This sucks, as I was louder with 1 sub than I am now with 2, and I now have twice the power...
Any suggestions?
Old Feb 27, 2009 | 06:42 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Second sub out of phase ?
Old Feb 27, 2009 | 01:24 PM
MadMaxSE-L's Avatar
Doggah Bite...
I was hoping this was it but no...
Old Feb 27, 2009 | 05:27 PM
nismos14's Avatar
§è~® f®ÈÄk
Maybe something is wrong with that particular xa4000's outputs. Try putting the input to the other xz4000 and use the output from that one to the first xa4000.
Old Feb 28, 2009 | 05:14 AM
MadMaxSE-L's Avatar
Doggah Bite...
^^^ I tried this as well and nothing changed. As much as it sucks, I think the "preamp outputs" are nothing more than internal signal splitters, and the signal if effectively getting 'halved" when I use another amp.
It just doesn't make sense to me and I am extremely disappointed...
Old Feb 28, 2009 | 09:30 PM
blktalon456's Avatar
Go to radio shack or you local stereo shop and get a set of y splits and hook it up that way. Make your single sub set of rca split into two.
Old Mar 1, 2009 | 05:19 AM
nismos14's Avatar
§è~® f®ÈÄk
Um why would he do that when thats exactly what the pass through is doing right now?
Old Mar 1, 2009 | 08:00 AM
MadMaxSE-L's Avatar
Doggah Bite...
Won't do that because...
I'm getting another top assembly for my old TC2k, so when it gets here I will re-check my wiring and everything. I may have had it wired out of phase in the first place, even though I checked it twice...
Old Mar 1, 2009 | 08:44 AM
nismos14's Avatar
§è~® f®ÈÄk
Never hurts to check.
dansmax2003
Jun 25, 2004 02:09 AM
WindFall
Apr 18, 2004 08:44 PM
astro1112
Jun 7, 2002 09:51 PM
klubjunkee
Nov 13, 2001 04:48 PM
