aftermarket stereo wiring problem
Old Nov 20, 2001 | 12:36 AM
tilt's Avatar
hey guys, im hoping you can help me out here.
I have a 92 maxima gxe with the active stereo system (non-bose).
I purchased an Aiwa cd head unit and trying to replace the factory unit. I also bought the wiring harness for the 92 maxima.
My problem is, I wired and matched-up (by color) the harness' connections to my new stereo but the darn thing just wont power up. The only wire i havent connected to the stereo is the power antenna. This shouldnt affect it right? If you can tell me if there anything i have left out or have anything in mind that might help, please let me know! Thanks.
Old Nov 20, 2001 | 03:54 AM
Coldboot-SE's Avatar
Tilt,
Don't always go by the wires color but rather their function
in the past I had either a Tenna or a Metra that didn't match
the OEM harness colors.
The 3 main wires to hook up
Battery - this is your constant 12v, Memory functions
Ignition - Turns on with the keyswitch, pwrs up HU and remote
Ground - self explainitory
With these hooked up the head unit should at least pwr up, if not get a meter and verify the 3 above, you may have a blown fuse or a bad connector.
Dave
Old Nov 20, 2001 | 08:58 AM
tilt's Avatar
Thanks, turns out i had the ground wired incorrectly... Matt93se pointed it out to me.
Old Nov 22, 2001 | 04:10 PM
ItalianMax2kSE's Avatar
in my 5th gen I had the same problem untill I plugged in my antenna wire.
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
JoshG
Sep 5, 2015 10:10 PM
A32goldylocks
Sep 2, 2015 06:39 AM
