question on metra 70-7551 harness
Old Apr 10, 2009 | 09:11 AM
Holty's Avatar
Do i need this or should i use this harness? I read in a post on this forum that i should use this harness, instead of the the normal harness that comes with the head unit installation kit? Crutchfield says this harness does not fit my '04 Maxima w/bose w/o nav.
Old Apr 13, 2009 | 05:43 AM
djfrestyl's Avatar
Suspension Yoda
If you want to install an aftermarket HU into your car with Bose, this is the harness you need.
Old Apr 13, 2009 | 07:05 AM
Holty's Avatar
thanks, i installed the hu over the weekend, this harness worked perfectly.
Old Apr 13, 2009 | 08:03 AM
taosd's Avatar
even if you have Bose, and don't have this harness, you can effectively make it out of some old RCAs and a regular harness... thats what I had to do, because I'm a fool and ordered the wrong one.
Old Apr 13, 2009 | 07:19 PM
djfrestyl's Avatar
Suspension Yoda
It works in the reverse fashion as well, if you want to add an aftermarket amp to the stock HU.
Old Apr 13, 2009 | 09:36 PM
ChiknNutz's Avatar
+1 for the metra harness. I just used this harness and it worked perfectly...but still have that darn POP issue when changing inputs or radio stations.
Old Apr 14, 2009 | 12:20 PM
djfrestyl's Avatar
Suspension Yoda
That's either your amp or your HU.
Old Apr 14, 2009 | 07:40 PM
Coolsaber57's Avatar
Wait, I'm having the same "Pop" issue with my GF's install. We have an alpine unit with 4v RCA outputs.
I used the metra 70-7551. I soldered all connections, and grounded the black wire from the HU directly to the chassis. For the other two grounds (the ones coming out of the harnesses), I tapped the HU ground.
We also are only getting sound from the rear speakers (well we get a real weak one from the driver's side front, but it's very low volume).
Any idea as to the cause or solution to the popping? What about the front speaker problem?
Old May 7, 2009 | 12:04 PM
VaicekaL's Avatar
Zip-tie all RCA's together - this will partially fix the problem
Zip-tie all 4 RCA's firmly together. This will stabilize RCA jacks in their sockets and will partially fix the problem, because some RCAs do not provide an adequate contact and you may hear a popping sound, especially while driving. I had the same problem with the 70-7551 harness. This fix eliminated the volume inequalities between the speakers and eliminated some popping. However, the popping sound during the volume change from 0 or to 0, the change of the input source, or the change of the radio stations is still present, but it is weaker now.
Old May 10, 2009 | 12:03 AM
That's a negative Ghostrider. The real solution to this problem is to use the harness that takes the speaker-outs and puts them through a LOC. Look in my other thread to see what its called. (i can't remember right now)
Old May 11, 2009 | 11:52 AM
Navara330's Avatar
Will this harness work for the 01 i30 as well?
Old May 11, 2009 | 11:53 AM
djfrestyl's Avatar
Suspension Yoda
Yes, it should.
Whitehouse Station?! I work off of 523.
Old May 11, 2009 | 11:56 AM
Navara330's Avatar
Yes, it should.
Haha where at?
Old May 11, 2009 | 12:00 PM
djfrestyl's Avatar
Suspension Yoda
One of the larger companies on that road...
Let me know if you ever need some help with your car, I do work for a lot of the local Maxima/Nissan guys. Nice to see another local orger.
Old May 11, 2009 | 12:01 PM
Navara330's Avatar
Very cool, do you live in the area?
Old May 11, 2009 | 12:03 PM
djfrestyl's Avatar
Suspension Yoda
Nah, about 30 minutes away.
Old May 12, 2009 | 12:22 PM
Navara330's Avatar
I posted this in another thread but thought that it would also apply here, its for us later gen i30/i35 guys. Its a new Scosche dash kit that looks to be more compatible then the Metra one.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=230285508567
Edit: Bought it and its even worse then the Metra one, i just cant win with this car....
Old Jul 21, 2019 | 04:14 PM
Dwayne Carter's Avatar
That is the exact harness that Crutchfield sold me for my 04 Maxima
97maximaman
Jan 24, 2008 03:30 PM
blkhawk500
May 19, 2004 10:38 AM
northrabbit
Jul 13, 2003 09:19 PM
