Bose emblem on sub cover causing rear deck rattle
Old Apr 27, 2009 | 05:43 AM
vball_max's Avatar
I found this out over the weekend. I did an quick search and could find any other posts on it. Mods, please lock it if it has been covered before.
I had the rear deck rattle so I dynamated it last summer. It helped a bit, but at certain frequencies, I still had a significant rattle.
So saturday night it was bugging the hell out of me. So when I went home i did some searching in the back seat. I found that it was the bose emblem plate on the sub cover. The small tabs on the back were not holding it securely so it was rattling.
So I took the sub cover into the house and popped the bose emblem off from the back of the cover (breaking off the tabs in the process). I took some super glue and glued it on. No more rattles.
Figured I would throw this out there incase someone is having the same issue.
Old Apr 27, 2009 | 06:59 AM
mannetti21's Avatar
interesting, I'll have to try this
Old Apr 27, 2009 | 08:02 AM
Jreed2008's Avatar
??? Humm my cover is off as we speak I thought the emblem was molded into the grille? I guess I will try it later also and report back
Old Apr 27, 2009 | 08:31 AM
vball_max's Avatar
Its pretty easy to check......if the cover is off, just tap it a few times....you will hear it if its loose.
6spd4dsc
May 9, 2022 12:30 PM
Matt93SE
May 24, 2019 02:58 PM
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
Mcnabb34
Aug 11, 2015 08:45 PM
