somebody helpppp
Old May 15, 2009 | 10:29 AM
dnozzle2789's Avatar
somebody helpppp
OKay, so long story short: One day last week, my driver's side front window wouldnt go up, the motor is fine, it just wouldn't go up. somethin to do with the window switch, took apart the door and looked at the switch, ended up breaking the window switch. had to rig the wiring to make that window work on a different switch. bought (off ebay) a 2000 infiniti i30 drivers side window control unit. shouldnt it be compatible with my 2000 max se? because when i plugged in the harnesses and put the wiring back to factory, it doesnt work for anything, it wont lock doors, it wont light up, it wont work the windows...is it just not compatible or is it broken, and if it's broken is there a way to put an ohmeter or voltmeter or something of the like to test it out and see if its broken.??? someone help because i cant stand leaving the windows up in ga heat with horrible ac.
Old May 15, 2009 | 11:28 AM
djfrestyl's Avatar
Suspension Yoda
Search. For the window reset procedure.
Then, buy the proper switch. Don't try to fix things if you don't know what you're doing.
Old May 15, 2009 | 06:41 PM
i knew what i was doing..thanks for the AWESOME advice
Old May 15, 2009 | 07:45 PM
djfrestyl's Avatar
Suspension Yoda
Well with a title that says 'somebody helpppp', it certainly seems otherwise. Good luck.
Old May 16, 2009 | 10:59 AM
Pearl96Max's Avatar
I tend to get a bit irritable
I think it was quite good advice. Were you expecting a spoon feeding ?
xloki77x
Oct 26, 2007 07:39 AM
flthere
18
Sep 7, 2007 11:37 AM
exit10
Nov 15, 2004 08:16 PM
AuToMaX_95
Mar 26, 2003 09:29 PM
flynlr
Mar 9, 2003 02:29 AM
