FM Reception, This normal?
Old May 20, 2009 | 02:03 PM
Domf3's Avatar
After installing the pioneer in my 01 Max (bose), I noticed a drop in FM reception. Sounded OK when parked then over the next few days while driving I noticed most stations have a slight crackle, and some are just terrible.
I read the threads and made sure blue wires were spliced. All connections are solid. Stations still come in but noticeably weaker. Is this expected from an aftermarket deck or do I need to troubleshoot some more?
Old May 20, 2009 | 04:02 PM
Jreed2008's Avatar
yeah its normal it gets worst when you go aftermarket, I also noticed it was worst when I had the blue wire connected So I un hooked and actually seemed to be better can't really explain it but I don't think its much that can be done about it
Old May 20, 2009 | 04:53 PM
Domf3's Avatar
Strange update
I was programming my PAC radio adapter, i moved it slightly... reception faded then nudged it again and it came back!? I wonder what this was about. I checked the wires.. tight? Any ideas. I'm curious if anybody has noticed the PAC adapter messing with reception?
Old Jan 31, 2012 | 11:15 AM
mau108's Avatar
Sorry to bump this old thread but in my search this thread best matched. Has anyone had luck fixing this issue ?
I also notice the exact same issue, installed a double din pioneer unit, used the antenna adapter and connected the blue wires up. I get fm reception and is fine for most stations when at a stand still but once moving fm is not as good as stock.
Old Jan 31, 2012 | 02:23 PM
mau108's Avatar
Would this adapter give better result then a diversity adapter?
http://www.installer.com/item/displa...php?it=40-ni11
http://www.installer.com/item/displa...php?it=40-ni10
Old Jan 31, 2012 | 02:35 PM
Brudface's Avatar
Putting an aftermarket deck in ANY car will yeail the same results.... you will losesome, or most of your signal Quality... which sucks for sure, but who installs an aftermarket deck to listen to the radio???
Old Feb 2, 2012 | 01:57 PM
mau108's Avatar
I like listening to morning shows on my drive in to work.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
