a couple of questions about my sub n amp setup...
Old Aug 3, 2009 | 06:33 PM
bigpopaj369's Avatar
so as the tittle says i have a few questions about my setup but before i ask i did search here and google for a while and yes i know my stuff "sucks" to most of u guys but its what i have until i have the extra money to upgrade as severely as i want to but i am layed off and im a single dad. So please spare the "upgrade your stuff sucks" replies. i have 2 12'' xplode subs in a bandpass box with a d1000.2 amp i want to make the best of what i have for now. just an fyi the ports are not tuned for these subs.the subs are facing forwards now and i usually fold down the seats for air flow to the amp. any help will be appreciated
#1 im curious as to if i would gain deeper more accurate hits with a sealed or ported box? an i know the "muddy" sound will go away even with what i have for an amp but will it be that much better? i ask because i know somebody with a few boxes for sale and i can get one real cheap
#2 should i face subs to front or rear? i was told bass is non directional but it was from someone at best buy so who knows if its true
Old Aug 4, 2009 | 05:58 PM
anybody at all?
Old Aug 4, 2009 | 08:28 PM
bigtech's Avatar
bass works off of reflection 9/10 times its better to run twords the trunk. i ran the same subs for quite awhile and there not too bad.. i ran one inside out and the other opposite with a non ported pro box pushed by a sony 1000 watt and it was decent. it also depends on what kind of music you listen to if you listen mostly to rock, techno and so on a sealed (non ported) box is what i would reccomend, hip-hop or rap i would go with a true ported box.
Old Aug 4, 2009 | 09:21 PM
AscendantMax's Avatar
bandpass boxes generally have a very narrow frequency response compared to a ported or sealed enclosures. sealed boxes will yield the most accurate response, since the tuning of a ported box will affect how it sounds. if the ported box is tuned high, you'll gain a bit of output, but the response will be a bit peaky in certain frequencies. low tuned ported boxes are great for a more linear output. so if you're going with the ported route, make sure you know the boxes' tuning (a lot of prefab ported boxes are tuned pretty high). so if you want more accurate bass response, go sealed. want a little more output? go ported.
Old Aug 5, 2009 | 05:10 AM
lopezi's Avatar
Nothing wrong with your equipment, people bag on Sony because they're hit or miss on some of their stuff but on average you can make their products perform pretty good.
The downsides of bandbass is getting them tuned right and its hard to know when you're causing the amp to clip because the enclosure masks when you're driving the subs too hard.
Ported enclosures work and perform fine but again it's getting the tuning correct for the particular sub you're using which means proper enclosure and port size.
The "easiest" is a sealed enclosure, a little bit more foregiving as far as exactness on enclosure. If space is a concern sealed is often recommended because you can usually make up for the lack of output from a samll enclosure by giving it more power (sealed enclosures are on the less efficient side).
On average, facing the subs rearward will give you roughly +3db gain as it uses the trunk to reinforce the output (trunk gain).
Old Aug 5, 2009 | 06:16 AM
thank u guys much appreciated and ya i do not find my products bad at all i had an 1000watt sony amp as well and now i have a boss d1000.2 people say its bottom of the barrel but hey it was all i could afford and to tell everyone the truth ive had so many people amazed with what i had. i usually listen to alot of music rap hip hop metal techno but whith this box ive been really pleased for the most part i just feel as if the box is bein pushed too hard. i will most likely find the specs for my xplode p5 subs and go ported guys rock thanks for he help.
Old Aug 5, 2009 | 12:00 PM
HMAX08's Avatar
Maxima.org members to the rescue, haha. btw your stuff is not bad, if you are on a budget. happy bangin
Old Aug 5, 2009 | 05:05 PM
haha yep thanks man. there are just some people who bash on lower end stuff but hey it slaps pretty good to me obv if i had money like these "bashers" id have sick stuff too
Old Aug 5, 2009 | 10:29 PM
bigtech's Avatar
if you get a chance jump on soundsolutionsaudio.com many people are on there and know exactly what there talkin about also check out sundown audio... its a company that me and my brother use and wow. if i can get permission from my brother ill post up a vid or two of his car.
Old Aug 6, 2009 | 07:15 AM
ok thanks bro thatd be great def interested in checkin it out if u get the chance
Old Aug 6, 2009 | 06:01 PM
bigtech's Avatar
http://www.youtube.com/watch?v=79FGIXlQedA
heres a quick walk around
http://www.youtube.com/watch?v=GJqDivB3j7Y
a hair trick.. keep in mind this is with out the seats folded down.
Old Aug 6, 2009 | 06:31 PM
that is def one sick setup im going to keep this in mind when i upgrade. that trunk lid was going nuts lol the hair trick was tight seats up and still moving air like that just sick thanks for the vids and advice man
Old Aug 6, 2009 | 08:53 PM
bigtech's Avatar
no problem if u need anymore help lemme kno btw what sony xplodes do u have red or black?
Old Aug 7, 2009 | 09:42 AM
i have the red ones i believe they are the p5's and thanks again bro
DJLAX152
May 4, 2021 11:46 AM
Violator
Sep 9, 2015 10:14 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
jfl330
Sep 4, 2015 01:44 PM
