My new system install in progress w/pics
Old Aug 23, 2009 | 10:05 PM
  #41
phxgold's Avatar
oh no they fit fine but when the kicks got painted and were up next to the old door panels with new leather inserts i was like what the hell lets clean this up.
I will call you tomorrow because I have some floor noise as well no alt whine but a hiss that can be heard between tracks on a cd or when the volume is down really low. I know with the caliber of this equipment if your not hearing music you shouldnt be hearing anything at all.
Old Aug 23, 2009 | 10:07 PM
  #42
phxgold's Avatar
Originally Posted by AscendantMax
i did something similar to my amps. i have the larger 4ch amp on the bottom and the smaller one right on top, at about a 30* angle.
old pics, but you get the idea. i'm sure yours will turn out a ton cleaner!
thats exactly what Im thinking but inverted so the top overlaps the bottom and mounted on the wall where the small amp is now. perfect pic too! Thanks.
Old Aug 24, 2009 | 11:29 AM
  #43
phxgold's Avatar
simplest option
Old Aug 24, 2009 | 12:01 PM
  #44
djfrestyl's Avatar
Suspension Yoda
That works.
Old Aug 26, 2009 | 12:43 PM
  #45
nismos14's Avatar
§è~® f®ÈÄk
Got any better pics of the hood struts setup in the trunk? Some detailed pics would help me alot.
Old Aug 26, 2009 | 04:14 PM
  #46
phxgold's Avatar
I take some for you tonite or tomorrow.
Old Aug 26, 2009 | 08:16 PM
  #47
nismos14's Avatar
§è~® f®ÈÄk
Thank you
Old Aug 27, 2009 | 10:14 PM
  #48
phxgold's Avatar
Thank you
havent forgot about you but by the time I got home it was dark so manana' I promise.
anyway here is the amprack solution in the dak of course. more pics in the am.
and of course the walkaround
http://video.cardomain.com/VideoPlayer.aspx?id=703692
Old Aug 27, 2009 | 11:22 PM
  #49
shadyonedeath's Avatar
beautiful man. nice work.
Old Aug 28, 2009 | 06:55 AM
  #50
nismos14's Avatar
§è~® f®ÈÄk
thanks, looks nice!
Old Aug 28, 2009 | 01:56 PM
  #51
phxgold's Avatar
day pics of amp rack
Old Aug 28, 2009 | 02:04 PM
  #52
phxgold's Avatar
OK so th hood struts are made by strong arm.
They are 19.7" long fully extended.
I started with 30 psi but that wasnt strong enough in my estimation. it held the trunk up when fully open but that was it. so I went up to 95 psi.
with the 95 psi when you hit the trunk pin the trunk opens all the way up for you automatically!
now to figure out a motor to close it automatically as well? ;0D
anyway. these struts come with 10mm ball socket mounts but the brackets are not included make sure you buy them. anyway we fabbed up a bracket to attach the strut to the trunk hinge where the scissor tension bar went thru
then we mounted the other sides bracket to the trunk wall behind the seat and pushed it thru the carpet covering to hide the bracket
Old Aug 28, 2009 | 08:47 PM
  #53
nismos14's Avatar
§è~® f®ÈÄk
thanks!
Old Aug 28, 2009 | 10:44 PM
  #54
phxgold's Avatar
no problem, wish I had a better camera.
Old Sep 6, 2009 | 09:38 PM
  #55
MURDRMAX's Avatar
man nate built my alts and it worked GREAT, the guy is good with the alts. can you have your seats redone with the memory foam? is that expensive? can you tell a differnce after its put in?
Old Sep 8, 2009 | 10:26 PM
  #56
phxgold's Avatar
I notice the difference its a firmer seat but comfortable like its built for you and you only no atter how you sit. cost was nominal.
Old Sep 9, 2009 | 05:58 AM
  #57
MURDRMAX's Avatar
i need to find a shop around here that can do that. i wonder how it will hold up in the long run?
Old Sep 9, 2009 | 06:09 AM
  #58
BLACKonBLACK98's Avatar
Former Vendor
to have it open and close automatically you can use a linear actuator. aka very popular "pop trunk" mod down here in houston.
Old Sep 9, 2009 | 06:11 AM
  #59
Former Vendor
should be very durable since memory foam will not loose it's shape over time. i had planned to do this for my max a while back but never got to it. still have a big slab of foam.
Old Sep 9, 2009 | 07:59 AM
  #60
Conrad283's Avatar
I need a truck
Nice set up
Old Sep 9, 2009 | 05:59 PM
  #61
AscendantMax's Avatar
looks much better now with the amps repositioned!
Old Sep 10, 2009 | 10:32 PM
  #62
phxgold's Avatar
Thx I caught the bug lmao
will replace rear speakers with dyn 242 2 wat set run passive will redo doors in rear to hold em. gotta dd another p2 ultra. and am now going active with the 362's with a zapco dsp6 will also put 2 TRU line drivers in the mix too.
so amp rack will change to a welded floating amp rack with a p4 and p1 on bottom and 2 p2's up top, lighting will as well in the next few weeks. debating a kenwood 9140 as well so the eclipse cd7200 might be up for bids soon. stay tuned!
Old Sep 10, 2009 | 10:43 PM
  #63
What are your thoughts about those IAs?
Old Sep 11, 2009 | 07:13 AM
  #64
phxgold's Avatar
AMAZING!
for a bit I was wondering about my purchase but I remember distinctly when it happened.
When I first had everything put in and tuned I was like hey this is a cool set up but I cant crank itbecause nothing was broken in yet. i left everything on overnight in the car for a few days and didnt really drive the car. i wanted to be sure I was breaking in the speakers and not just my ear ya know.
Then on saturday I was sitting in my car out in the garage having a beer (kids took over my man cave lol)
i was playing santana supernatural and it was like the subs turned into what they ar esupposed to be it was like 1 minute they were just subs and instantly they became something more.
"do you like the way" came on and all hell broke loose. My car was something different I cant explain it really its just the low end ive heard in the past always to me was a monotone bump bump boom. This was different I didnt just feel the bass I heard the bass (make sense? i hope so becasue thats the only way I know how to describe it) it separated the sub channel into an insturment with personality instead of a filler.
so since it was such a dramatic change I swapped out the cd for my ipod and started playing a track off of def jazz called Ghetto Jam if you havent heard it the bassline is insane! real stand up bass jazz cover of an old school rap tune (buy this album if you like sq!) anyway the bass line was true accurate in no way boomy I guess they call this "transparent?" it blended with the dyns flawlessly and hit every note like someone was sitting in front of me pluckin away on a stand up bass. the kickdrums comming out of the 8" midbass and those subs together are a dream! if you want to go IB i say IA period bar none I personally have never heard anything like it.
Old Sep 11, 2009 | 07:23 AM
  #65
nismos14's Avatar
§è~® f®ÈÄk
AMAZING!
What other subs have you used IB?
Old Sep 11, 2009 | 07:40 AM
  #66
NissanMan97's Avatar
looks good! cant wait to get my new car and put all my stuff back in.
this is to whoever had the Hertz sub, how does it sound? how many watts are you pushing? I had component Hertz up front and 3 ways in the back with a 600w amp powering the fronts. I was gonna add a sub or 4 but wrecked the max, wanted to know what they sounded like
B
Old Sep 11, 2009 | 07:49 AM
  #67
phxgold's Avatar
First IB set up for me personally.
But I have heard AE, IDQ and IDMAX in similar installs none of those were quite what I hear from these flatlynes. The funny think is I bought the flatlynes based solely on reviews I had read by sq competitors on DIYmobile audio. not only did I want to try them because of teh write ups but I also like having something different than everyone else. alot of people look at you like your crazy when you say you have IA since they dont know what they are. I had never heard them before.
I liked what I heard from Image dynamics but the reviews I read basically were right IDQ is the **** when it comes to IB but flatlynes are something more.
something else that was different for me. I have always had boxes for my subs. when I open my trunk while music is playing there is very little sound comming out of my trunk even tho my cabin is filled with sound. I will admit that I never listened to an IB set up before with the trunk open. but I thought that was weird. also all trunk rattling is pretty much gone. granted the struts are there now which push up on the trunk putting it firmly against the latch. but based on the lack of bass comming out of the trunk when the trunk is open I think the sound waves are all being pushed inside the cabin which is deadend beyond belief.
Hones to god everything inside the car can be sheer pandamonium but outside you hear very very little when the doors are shut and windows are rolled up. Just an observation.
Old Sep 11, 2009 | 08:47 AM
  #68
this is to whoever had the Nertz sub, how does it sound? how many watts are you pushing? I had component Nertz up front and 3 ways in the back with a 600w amp powering the fronts. I was gonna add a sub or 4 but wrecked the max, wanted to know what they sounded like
B
do you mean hertz...?
Old Sep 11, 2009 | 09:50 AM
  #69
lol...yea sorry i didnt realize i was hitting H
B
Old Sep 11, 2009 | 08:09 PM
  #70
phxgold's Avatar
B
"do you mean hertz...?"
B
Old Sep 13, 2009 | 01:27 PM
  #71
maxgtr2000's Avatar
KH3 by popular demand
I hope to see and hear this set up at a meet. Bagged and turboed soon. Interesting. I've never personally heard an ib setup I want to get away from the sub box scene too and free up some space even though mine is fiberglass.
Old Sep 17, 2009 | 08:59 AM
  #72
B
B
yea again not very smart coming from me. I mean Hertz not nertz.
B
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
A32goldylocks
Sep 2, 2015 06:39 AM
Maxima_Joe
Aug 27, 2015 12:01 AM
