Need help with FRONT SPEAKER replacement on 5th gen 2003 Max
Old Jun 26, 2010 | 01:27 PM
Maxxxed's Avatar
tEh Hope
I am trying to replace stock speakers in my front door panel with Polk DB651. Before purchasing these, I checked on Crutchfield and their website said these are compatible with 2003 Maxima.
I removed the inner door panel to get to the speaker and this is what it looked like:
As you can see from the above pictures, its a simple plug that fits directly into the socket of the speaker.
Below is an image of the POLK speaker that I am trying to install. As you see, it doesn't have any socket. Can someone guide me what I need to do to install this speaker. Does Nissan or Polk sell some sort of socket/adapter that I need?
Old Jun 26, 2010 | 02:11 PM
1800bucks's Avatar
You can do what I did and simply took a dremel and cut everything out leaving the outer edge to screw the speaker to. Let me see if I have a picture of the factory ring with the paper cone and plastic removed. I have a set ready to drop your new speakers into if you need them.
Old Jun 26, 2010 | 02:15 PM
1800bucks's Avatar
Here, I found a pic of a set of rings that have been cut. I feed the new wires thru the white square were the OEM harness went thru.
Old Jun 26, 2010 | 03:01 PM
Maxxxed's Avatar
tEh Hope
that sounds like a lot of work.. plus I am trying to salvage the stock speakers (I will put them back in when I sell the car).
If worse comes to worst, I will probably end up doing what you did, but there has to be an easier way, as I can't imagine everyone having to do this if they want to replace the speakers.
Old Jun 26, 2010 | 04:16 PM
mendon99's Avatar
tastey wheat
you need to purchase some 6.5" MDF speaker rings. 3/4" or half thick would be fine.. get them on ebay or you may try a local stereo shop.
Old Jun 26, 2010 | 04:30 PM
AscendantMax's Avatar
yep, definately need some MDF rings. you can PM Pearl96max...i THINK he still makes them for people.
Old Jun 27, 2010 | 02:17 PM
Jreed2008's Avatar
reuse stock brackets just sit your new speaker in a screw them down, and for the harness cut off the white connector and strip the wire crimp on aftermarket speaker connectors and your done just make sure you know which is pos+ or neg- coming from the car
Old Jun 28, 2010 | 01:08 PM
Maxxxed's Avatar
tEh Hope
Thanks! I just wanted to make sure before I cut off the white connector that it was OK to do it.
How can I tell which one is + and which is - coming from the car??
Old Jul 5, 2010 | 09:41 PM
V2subzero's Avatar
hook it up witch ever way u think turn car on if it works ur good if not reverse
Old Jul 14, 2010 | 05:22 PM
Pit5Bull's Avatar
You could always do this...
Build your own baffles out of MDF...
Worked really good for me when I replaced the Bose in my 5th Gen... You can just use the factory baffles as a guide for fitment and if you plan to replace the factory speakers when you sell the car, you can drop them in with the original baffles without any issues.
Hope that helps!
Old Jul 14, 2010 | 07:03 PM
Andrew's Avatar
Hope that helps!
Could you give us a bigger pic of those nice mdf rings?
Old Jul 14, 2010 | 07:50 PM
Goomz's Avatar
but to answer the question asked, yes they do sell speaker harness adapter's, which is a plug and play part, available at your local best buy, etc in which you dont have to cut the factory plug
Old Jul 15, 2010 | 04:38 PM
Pit5Bull's Avatar
@Andrew...
I wish I could, but they're hosted on my cardomain page. For some reason, I can't post the full-sized photos from there and I have no idea where I saved the original photos I took... :|
If you know how, I'll repost them so you can see what I did, otherwise the best bet would be to look at my cardomain page so you can blow the photos up.
Here's my page: http://www.cardomain.com/ride/2048098/1 (see p.2)
Looking back at them, I hate that I didn't give myself the time to remove all of that stuff from my old car before I traded it in on my new one... now I'll have to do it all over again... :-P
Oh well, I guess it's just another photo opp whenever I do decide to do this again!!!
Old Jul 15, 2010 | 07:49 PM
Andrew's Avatar
Now when you cut out the rings, did you do it in 2 pieces? First the flat cut out and then the ring?
MikesChevelle
Nov 23, 2024 11:17 AM
CRizz
41
Jun 7, 2021 05:42 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
jskirwin
Jun 8, 2016 08:49 AM
Mcnabb34
Aug 11, 2015 08:45 PM
