Why does my amp turn off when I play a CD?
Old Oct 12, 2010 | 12:02 PM
MaxedOut513's Avatar
Hello I am in need of some assistance. I own a 2000 Maxima that is equipped with the Bose system. I recently installed my amp and subs from my old car into my Maxima. The amp and subs work fine while playing the radio, however, the amp powers off when I play a cd. I had to install the PAC AOEM-NIS2 unit for RCA's and remote to hook up my amp. I think the problem may have something to do with the remote lead but im not sure how to fix it. Thanks for your help!
Old Oct 12, 2010 | 01:09 PM
MadMax07SL's Avatar
Your remote on wire is hooked into the power antenna wire probably. When you switch to CD, the car puts down the antenna right? You can't use that setup for your amp.
You need to hook up the remote power on wire to something that lights up with ignition, there's usually several places in the fuse block...
Old Oct 12, 2010 | 01:57 PM
ekrunch's Avatar
+1
If you're using the OEM-1, check to make sure you didn't tap the Blue wire on the input side... that's the power antenna. Tap the blue/white wire on the output side, that's the remote turn on. (I'm working from memory here so forgive me if I'm off a little, but the manual for the OEM-1 should tell you)
Good luck!
Old Oct 12, 2010 | 02:00 PM
ekrunch's Avatar
One note. If you have a remote turn on option, use that instead of an accessory wire connection. The accessory lead will power up your amp before your radio comes on and you'll usually get an annoying pop when the radio powers up and starts sending signal. The remote turn on will only put power to the amp when it needs to have it, not the whole time the car is running.
Old Oct 12, 2010 | 02:48 PM
Joeker82's Avatar
I second the power antenna lead. Just need to swap it out to the remote lead.
Old Oct 12, 2010 | 04:00 PM
Thanks for the help, my suspicions were correct. The weird thing about the PAC unit was I thought it was supposed to spit out a remote lead (blue and white) but it spits out a power antenna lead (blue). So i assume I need to figure out a different location for the remote lead? Any suggestions?
Old Oct 12, 2010 | 05:44 PM
Joeker82's Avatar
Track down something with a ign switch and tap into that. According to the diagram below you can tap into pin 12 green/white. This is what I would do.
http://www.nicoclub.com/archives/5th...ing-codes.html
Old Oct 12, 2010 | 05:58 PM
Hmm yea that might work. Ill try that tomorrow unless anyone has a better idea??
Old Oct 12, 2010 | 06:01 PM
Joeker82's Avatar
These are your friend! That way you dont have to cut anything!
Old Oct 12, 2010 | 06:02 PM
Joeker82's Avatar
Give it a whirl! I'm about 99% sure this will solve your problems...
Old Oct 12, 2010 | 06:17 PM
Oh nice.. I was just about to ask if I would have to cut to tap, which I dont really want to but will if necessary. Are those common in hardware stores? And if I cut would it mess up anything else? Sorry im kinda new to car audio.
Old Oct 12, 2010 | 06:23 PM
Joeker82's Avatar
You can get those at any auto parts store (autozone, pep boys)
If you cut it, just splice and reconnect. Use a pigtail connector. I would avoid cutting if you can, Just pick up some of those. Shouldn't be more than $5 bucks, you get 5 or so in a package.
Old Oct 12, 2010 | 07:38 PM
Ill be stopping by autozone tomorrow. Thanks bro ill post my results.
Old Oct 12, 2010 | 09:06 PM
Joeker82's Avatar
No problem buddy! Can't wait to hear the good results!
Old Oct 12, 2010 | 10:03 PM
ekrunch's Avatar
It might be worth a quick note to PAC tech support. That thing is supposed to have a remote turn on. Something isn't right there...
Old Oct 13, 2010 | 06:44 AM
Yea Im gonna double check before I call them but Im positive the wire on mine has no white stripe.
http://www.sonicelectronix.com/item_...AOEM-NIS2.html
Check out the large image of it and you can plainly see that one has a blue n white stripe.
Old Oct 13, 2010 | 11:59 AM
ekrunch's Avatar
If it were me, I'd get a meter, put it on 12vDC and check the wires on the input side. Seeing as your system has an amp, it most likely has a remote turn on that's coming in from the factory harness to the OEM-1. Judging by this picture of the ADD-NIS2 harness, there is a blue/white wire in the same harness as the purple/green speaker wires. Use your meter on that wire and a ground with the radio in CD player mode. If you've got 12v on it, put a t-tap on that wire and go for it!
It's worth a shot.
Old Oct 13, 2010 | 12:02 PM
ekrunch's Avatar
Looking more closely at the picture, the wire I'm talking about actually has the word "remote turn on" printed on it in little tiny letters. That should definitely do the trick.
Old Oct 13, 2010 | 01:27 PM
Okay I messed with it for a minute and im kinda confused. The PAC unit does spit out a remote wire on the output end along with the RCAs. However, on the input end of the PAC unit there is no remote wire, but there is a power antenna. There is a remote wire within the PAC unit but it runs directly from the input connection for the HU to the output in the factory harness. And I dont see a remote wire on the factory harness.. WTF?
Old Oct 13, 2010 | 01:29 PM
And ekrunch that picture is a different PAC unit then the one I have. I posted a link to the one I have.
Old Oct 13, 2010 | 02:00 PM
Joeker82's Avatar
lol! Just tap into pin 12. It could be that easy
Old Oct 13, 2010 | 04:22 PM
ekrunch's Avatar
Then that might be your problem! The link I posted was one that I followed from the link that you sent. You need to verify that you have the right harnesses from PAC. They might have screwed up. From the link you sent...
This AOEM Kit Includes the following:
The last harness is the one I was referring to. The harnesses should have tags on them that say AMP-RCA and ADD-NIS2. Which ones do you have?
Old Oct 14, 2010 | 08:59 AM
Oookay I see now. Sorry im retarded lol. I do have the whole PAC kit. When I get home im gonna tap into the remote and see if that works. Ill let you know how it goes!
Old Oct 15, 2010 | 07:21 PM
DcMaN's Avatar
You hooked youre remote turn on wire from the amp to the power antenna input by accident on the headunit, which is why when you switch the source input to CD the amp turns off because it has no need for the power antenna to be in use for a cd. Look for the remote turn on wire (usually blue/white or Blue) on the headunit. If there is not one available, hook youre remote wire into a a +12v switched input
Old Oct 15, 2010 | 08:41 PM
Joeker82's Avatar
Yea, I think we already clarified this...
Old Oct 17, 2010 | 07:30 AM
I tapped into the remote amp turn on wire and got it workin! Thanks krunch n everyone else. Its weird how the PAC kit has the remote amp wire setup within it. The OEM1 spits out a remote wire, but the NIS2 remote wire goes directly from the HU to the factory harness, so it doesnt even connect to the OEM1. weird...
Now I just have to get my car running lol. Hit something the other day that screwed up my oil pan or something n all my oil leaked out :-(
Old Oct 17, 2010 | 10:22 AM
Joeker82's Avatar
Good deal. Your welcome.
Old Oct 17, 2010 | 06:35 PM
ekrunch's Avatar
Well at least you can listen to a CD while you work on it.
Glad that worked out for you man. It's weird that the OEM-1's remote did that, but stranger things have happened. Oh well, as long as it's working now!
captchaos
Mar 15, 2016 12:18 PM
Smackasmith
Feb 1, 2016 12:40 AM
LtLeary
Sep 14, 2015 12:33 PM
popdedop
Sep 11, 2015 11:17 AM
