Transistor Horn install
Old Mar 28, 2013 | 06:37 PM
nycspudz03's Avatar
I need some help installing some aftermarket transistor horns in m 5th gen and I just need some clarification. I think the aftermarket horn has a positive trigger and the stock maxima horn is a negative. Im trying to figure out how to wire the new horn without having to wire up another horn switch.
After reading up I understand that the pins are to be wired as followed
Pin 87: +12v from battery
Pin 86: +12v from horn switch
Pin 85: -12v to ground
Pin 30: +12v to horn
But I'm still not understanding pin 86(from the horn switch) Where do I tap this wire from? By the stock fuse box? or what?
Old Apr 11, 2013 | 03:57 AM
Hectic's Avatar
Since it's a negative trigger, the diagram is the opposite of what you want. 86 should be wired to a constant source, 85 should be from the horn switch.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
