security system problem
Old Jan 15, 2002 | 06:13 AM
rjborg
A recent minor front end accident has caused my security system to sense that the hood of my 1986 Maxima is constantly open. The constant blinking of my dashboard security light drains the battery. Replacing the hood did not solve the problem.
I cannot find the faulty sensor/switch under the hood. And I don't know which fuse I could pull to disable the system. Advice on either of these two approaches, or another approach, would be appreciated. Thanks.
Old Jan 15, 2002 | 07:03 AM
jiaxima96's Avatar
If you pop up the hood, you should be able to see a push-down switch (you can call it a sensor) on right side on the front frame. Close all the doors and trunk, have someone press that hood switch down, and you can check the dash security light see if it's still blinking...
Old Jan 15, 2002 | 07:18 AM
jiaxima96's Avatar
Oops I realized this is not the 4th gen forum. Mine is 96.
Old Jan 15, 2002 | 07:40 AM
rjborg
jiaxima96 - I'll have look at my '86 for the switch you have on your '96. I think there IS something there near the front on the driver's side, but I did not recognize it as anything special. Thanks for the quick reply.
DJLAX152
May 4, 2021 11:46 AM
gustavison
Oct 4, 2015 06:50 PM
carid
Sep 9, 2015 05:06 AM
slowlifer
Sep 8, 2015 05:53 AM
