Best 4-channel amp for 200-250$??
Old Jan 16, 2002 | 06:17 PM
NYCe MaXiMa's Avatar
I'll be looking to get an amp in the near future to power my stock speakers, the headunit made a difference but not enough, there is still rattle and static at higher then average volume.
I'm not looking to go deaf and set off car alarms from 2 blocks away when I'll be adding a sub and upgrading speakers later on. But what is a good quality amp, reliable and good for crisp sound, even at high volume? I would like to spend about 200-250$ on this thing.. Someone reccomended Eclipse, not sure of exact model.. but what do you think, and what would you reccomend?
thanks
Old Jan 16, 2002 | 06:30 PM
AndyXXL's Avatar
Re: Best 4-channel amp for 200-250$??
You will not get a good crisp sound out of stock 25 watt speakers even if you use the best amp ever.
Get Eclipse 82641 speakers instead.
Old Jan 17, 2002 | 04:33 AM
jim90gxe's Avatar
It may not be the best but I got a 4 channel Hifonics z440 for $200. It's rated at 55w RMS/channel.
Old Jan 17, 2002 | 03:01 PM
Re: Re: Best 4-channel amp for 200-250$??
yes, i realize that.. but it should be better for the time being, i just can't afford speakers right now, so I'm thinking i'll add an amp, then do the speakers when i can.
Old Jan 17, 2002 | 04:32 PM
AndyXXL's Avatar
Re: Re: Re: Best 4-channel amp for 200-250$??
Why not do it the other way? Get nice speakers now and power them from the headunit and get an amp later on.
Old Jan 18, 2002 | 12:12 AM
Nismo's Avatar
Re: Re: Re: Re: Best 4-channel amp for 200-250$??
thats what I was going to say
Old Jan 18, 2002 | 02:41 AM
SWEETSOUND2001's Avatar
main problem in the factory system is the lack of power. When you replace speakers, you still have the same amount of power and distortion going to them. When you amplify the factory speakers, you are removing the low bass frequencies from the speakers allowing them to play clearer and much louder.
Anton
Old Jan 18, 2002 | 05:25 AM
AndyXXL's Avatar
Originally posted by SWEETSOUND2001
When you replace speakers, you still have the same amount of power and distortion going to them. Anton
Not with the aftermarket headunit.
Also, NYCe Max if you decide to power your stockers from the amp consider getting a sub too cuz just like Anton said you're going to lose some bass...and it's not fun without bass.
Old Jan 18, 2002 | 02:53 PM
soundmike's Avatar
Very sound, Mike
Just to add to the list, i'd recommend the JBL 80.4. It's a nice piece of work.
If you want cheap and a relatively good amp check out the Pioneer 354. It retails for $100 on ebay right now.
Old Jan 19, 2002 | 01:50 AM
I see.. Well, I will see, perhaps I'll just shell out for everything at once.. add the sub and sub amp later..
Hurry up and get that 530i so i can take ur speakers
Old Jan 19, 2002 | 10:28 AM
AndyXXL's Avatar
Dude 3-4 months at the most, please be patient
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
