Sub and amp install
Old Dec 19, 2015 | 09:20 PM
ozsi's Avatar
Sub and amp install
Im installing a sub with an amp to my 14 maxima with the stock radio. Question can it be installed separate from the stock speakers so i can use a bass *** to control the sub.
Old Dec 19, 2015 | 10:44 PM
Cotozic's Avatar
Yes. Most amps will have an remote control **** that you can plug into it and run under your dashboard, or wherever. Whatever is attached to that amp is what can have their levels adjusted by the remote control, so I'm assuming you're just leaving the stock speakers attached to the radio outputs. So if you just wire your sub to the amp, only the sub bass level will be adjusted with the remote.
Old Dec 22, 2015 | 10:09 PM
1996blackmax's Avatar
This was the first mod to my 7th gen. It will really help your system as the bass is pretty anemic in our cars. Cotozic explained it well.
11maximaSV
Oct 30, 2015 02:09 PM
seesole
Oct 26, 2015 09:08 PM
TriniMax3.0
Oct 22, 2015 11:19 AM
sliptap
Sep 30, 2015 05:57 AM
