grounding my amp???
Old Jan 30, 2002 | 04:19 AM
Andre 3000's Avatar
grounding my amp???
im installing my amp under the driver seat of my 95...wheres the best place to ground it? please be specific cuz i tried and failed once already. i tried the seat beat buckle screw but it didnt work.
Old Jan 30, 2002 | 07:47 AM
burrll_gee's Avatar
I used the bolt that holds the chair to the floor.
And a large eyelet Yellow i think. They are color coded by size.
Works fine, no ground loop or anything.
bg
Old Jan 30, 2002 | 08:49 AM
maximadave's Avatar
detailerdaveb@gmail.com
Amps should always be grounded to chassis, not to a seat bolt. The gound wire should not be longer than roughly 6-8 inches from the amp to prevent noise.
Old Jan 30, 2002 | 10:21 AM
burrll_gee's Avatar
The seat bolt threads into the chassis?
And the bottom of the eyelet is flat on the metal floor i filed the paint off of, so that is a good ground no? this was the only way to make gound wire be < 8"
Old Jan 30, 2002 | 07:05 PM
ny96max's Avatar
directly below the seat is sort of a hump under the carpet(right near the floor vent). Cut back the carpet and ground your amp there, use 2 screws to firmly secure your ground. Oh and also get sand paper and sand down any paint thats on there to bare metal for the best contact!
Ant
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
