AMP settings~~
Old Feb 10, 2002 | 01:23 AM
skyjay617's Avatar
AMP settings~~
guys, just need the advises for my amp settings.....would u please advise me with the following settings like tell me which one should i set them on??
HPF-FULL-LPF it's currently on LPF. I felt like it sounds louder
when i set it to FULL, anyone recommand me to do that??
MONO-STEREO it's currently on MONO, i can't feel the difference
when i set this to stereo...but which one is good
suggestion??
LPF 30hz-250hz it's a screw...should i adjust it?? or just leave the
the way it is?? and how do i know what frequency is
currently on since it's a screw?? otherwise, should i
set them higher?? or lower??
HPF 30hz-1khz same question to LPF setting.....higher?? or lower??
thank you very much.....i am very appreciated.....
Old Feb 10, 2002 | 07:19 AM
Micah95GLE's Avatar
We don't know what speakers the amp is pushing, so we can't tell you how to set the crossovers.
Old Feb 10, 2002 | 11:00 AM
max'n out's Avatar
Re: AMP settings~~
suggestion??
I take that you have a 4 channel amp? Which one? What channel is driving what speakers? How is it wired up? But yes you need to play with all of them. To what afect depends on my questions.
Old Feb 10, 2002 | 12:06 PM
skyjay617's Avatar
Re: Re: AMP settings~~
oops.....sorry guys....i had a 2 channel amp, it's DHD 150x2....it's cheap...the stereo shop wired for me....so actually i dont really know.....i have a PPI 300w 12" woofer
Old Feb 10, 2002 | 12:11 PM
max'n out's Avatar
Re: Re: Re: AMP settings~~
Alright so if they wired it and set it up why are you messing with it? But the basic setting would be this:
Low pass
If it's wired in mono it should be on mono, and it probley is
x over point, they probley set it, somwhere around 80-100 hz
Old Feb 10, 2002 | 12:45 PM
Punch84's Avatar
Hi. I have a couple of questions too. I hooked up 1 JL 10w0 to a RF 160.2 myself and I dont know where to set the gain. Does it matter? And where do I set the crossover, Low, High or Full? I am running it mono. Thanks, Dave.
Old Feb 10, 2002 | 01:36 PM
max'n out's Avatar
Yes it matters alot. If your looking to make it loud, basically turn you head unit volum up to the loudest point you keep it, then go to the amp start with the gain at zero then begin to turn it up, when it clips back it down 1/4. Set the x over on Low.
aw11power
Oct 10, 2021 04:57 AM
chisam14
Nov 6, 2018 08:56 PM
knight_yyz
Nov 1, 2015 01:34 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
