rear speakers are making strange sound....
Old Nov 17, 2000 | 08:57 PM
Nick Robinson's Avatar
They make a strange pop sound. Its not really a pop, its really hard to describe. Anyway its just the rear speakers, and the first thought i had was i blew them. But i got to thinking, and there is NO way i could have! I noticed it today after school, i figured right away it was my speakers, so when i stopped the car, i went in the trunk and i could hear it coming from the speakers.
I havnt cranked the system up at all. I do keep the Bass at +4 which is the heighest level, but i dont crank the sound up too high.
I dont have a stock head unit or stock speakers. The HU is a Kennwood and the speakers are Panisonics. Any ideas what this could be?
When i turned down the Bass it was much less frequent, and might have stopped all together (maybe...) Is keeping the bass +4 bad? I wouldnt see why, or else why would it be there!
Old Nov 17, 2000 | 11:42 PM
Ryan93SE's Avatar
make sure your connections are still secure...
i had the same problem and it ended up the sauder had come off of one speaker and the connection was loose
Old Nov 17, 2000 | 11:59 PM
MaxRod33's Avatar
It sounds like you definitely might have blown it. Try listening at lower bass levels, you should lose the "pop" noise. Maybe somethings stuck in one of them? I dont think so though. What happened to your amp/subs on the way? Did everything work out? Sometimes if you fool around with the wiring, things get messed up, so check that. Good Luck.
Old Nov 18, 2000 | 05:16 AM
they just arrived
My new amp and subs just came, and im going to install them today. I looked really quick to see if anything was disconnected yesterday, but ill check again today in the light.
Old Nov 18, 2000 | 07:52 PM
Ryan93SE's Avatar
hpw did everything work out?
MikesChevelle
Nov 23, 2024 11:17 AM
jskirwin
Jun 8, 2016 08:49 AM
melteye
May 16, 2016 12:02 AM
Huttig2009
Sep 25, 2015 03:31 PM
Mcnabb34
Aug 11, 2015 08:45 PM
