Bose sound(95 SE)
Old Mar 2, 2002 | 03:23 PM
skuccio's max's Avatar
Beast Mode!!!
Bose sound(95 SE)
I know the amp supposedly puts out 200W peak of power, but when I turn it up, the woofers bottom out and the tweeters clip and distort. Would it be wise to change the woofers and tweeters only, or should I go for a whole new system? I like the look of the stock Bose radio, and since Bose doesn't make aftermarket radios I don't want to replace it.
Also, could I replace the woofers in the Maxima with woofers from my house? I have a couple of pairs of old speakers lying around, and I think they're powerful enough for the amps. I know car speakers usually run at about 1-4 ohms...would 6-8 ohm speakers destroy anything?
Old Mar 2, 2002 | 03:32 PM
97StockSE's Avatar
You can put your home speakers in your car and it won't hurt anything, however, your amps will "see" twice the resistance, 8 ohms instead of 4 ohms, so you will only get half the power out of your amps. As far as replacing the Bose speakers, as long as you replace them with speakers that have the same impedance (4 ohms or whatever),I think it would be fine. I'm just guessing at that however as I have never worked on a Bose system, and they may wire their systems differently than standard stock systems. Hope this helps.
Mahmuth
Aug 16, 2024 08:23 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
