My new L:exus LS400 installation pics.
Old Mar 20, 2002 | 12:31 AM
SWEETSOUND2001's Avatar
Well, this is just the beginning and I'll have a lot done by the end of spring break (11 day vacation)
http://www.clublexus.com/forums/show...&postid=263366
I'll keep you guys posted. Any suggestions, comments? Jmax?
Anton
Old Mar 20, 2002 | 01:05 AM
Mike H.'s Avatar
Is this usually a 1 day project for you or do you have your car gutted over a couple of days? I plan on sound dampening my car soon but I don't want the car to be out of commission. What do you recommend? Do things one at a time? TIA. Oh yeah, that carpet padding that you used on your Max, where did you get that again? What lbs is that? Any better and heavier than the stuff from Home Depot? I'd love to see your dampening project in person so that I may get some tips. Thanks again.
Regards,
Mike H.
Old Mar 20, 2002 | 06:21 AM
Conrad283's Avatar
I need a truck
wow that car looks like it was stripped and left on concrete bricks
Old Mar 20, 2002 | 07:15 AM
Whitemax's Avatar
Disco Biscuit
As always Anton, I am humbled by your projects! Good luck, and keep me posted....
Old Mar 20, 2002 | 10:34 AM
jmax
Anton, now that's how I like to see a fine automobile. I am still jealous of a garage that can fit a car with the doors open!
Reference the 3 inch gap between to of rear deck and bottom, I would use fiberglass resin. Build it up good and strong for a perfect seal. Attach the top of the box, ie the baffle to the bottom of the deck, but first layer it in masking tape. Then use clay, plumbers putty, masking tape or whatever to outline an outer frame for the build up. You could build up the inner ring with masking tape - at least two layers. Then drill one or two holes in the deck lid to inject resin. You can fill a cake frosting decorating bag with resin (with filler material, sawdust, glass microspheres, whatever) and inject it right in the hole until the ring is filled. That way you have a solid ring right up to the opening. As you know I have been filling numerous holes in the area's around my rear deck. And when womething has to be clamped around an above said hole, it needs to be stucturally sound, not squishy. Then when you actually install the box you can use a more normal 1/32 to 1/8 inch gasket material.
Next, what is that metal circular thing in the center behind the rear seat? Is it the fuel pump cover, like under the seat of the maxima? Is that tool box mine? That roller with the black rubber adhesive stains looks very familiar.
You could probably put the servo controller in one of the rear quarter panels. May even fit an amp in each side. You would just need to be careful how you run the power wire so that it doesn't cross the RCA's - because both sides of the car would be used for both. I would run the power around the back of the trunk to the smaller amp.
Old Mar 23, 2002 | 10:06 AM
I dremeled the MDF baffle in such a way, that there is only a 1/4" gap. I will post some pics of it soon. Please revisit the link above, I added more pictures.
Anton
Old Mar 24, 2002 | 12:51 AM
retrodrive's Avatar
Wow JMAX...glad to see another audiocrazy person here
Old Mar 25, 2002 | 12:58 AM
jmax
I'm not crazy. And those voices frequently make good suggestions. I also almost never follow their advise if it might get a normal mortal into trouble. Oops, forgot to revisit the link. Talk back at you later.
Old Mar 25, 2002 | 09:31 AM
Max2000's Avatar
damn... anton.... LS400 is quite already..... when you are done.. you must have no sound whatsoever when you drive
Old Apr 1, 2002 | 10:28 PM
Alexis's Avatar
Sweetsound,
What happened to that thread at club lexus? I was going to show it to a friend.
btw, did you try taking an SPL meter to the LS before and after the raam matt?
Old Apr 2, 2002 | 01:06 AM
retrodrive's Avatar
Yeah, how is that thing coming? I am almost done on mine. Putting everything in tomorrow. There is a little meet in Hunington Beach and there will be a bunch of people with some good Rainbow / ARC / ID equipment. I'll e-mail you the place and time, I'll be there so you can check how my system sounds.
Old Apr 2, 2002 | 06:08 AM
Conrad283's Avatar
I need a truck
i think the link is bad
Old Apr 2, 2002 | 07:25 AM
jmax
I had to upgrade my browser to get the link to work.
MaxLife17
Jun 27, 2019 01:37 PM
t6378tp
Sep 29, 2018 04:27 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
timmay5835
Sep 15, 2015 06:09 PM
