14.4 Volts?
Old Mar 27, 2002 | 08:48 PM
PATRICK94SE's Avatar
14.4 Volts?
Just wondering what is up with Amp companies rating at 14.4 volts?
Old Mar 27, 2002 | 08:50 PM
max'n out's Avatar
What are you wondering?????
Old Mar 27, 2002 | 08:53 PM
I now more than average about cars but don't know this, Why/How would the amp recieve 14.4 volts in a normal situation? I thought cars were on a 12 volt system. So my real question is would an amp in my car get 14.4 volts going to it?
Old Mar 27, 2002 | 08:56 PM
max'n out's Avatar
It's possible, at rest with the engine off my battery puts out about 12.7 volts, on the highway it can range from 13.7 to 14.3 according to the digital gauge measuring voltage off the battery. The reason they list both is do to this reason.
Old Mar 27, 2002 | 08:59 PM
Thanks, I assumed it was a marketing tactic to make it seem as though an amp would put out more power than it actualy would in a normal
set-up.
Old Mar 27, 2002 | 09:18 PM
Matt93SE's Avatar
STFU n00b!
reason being is that for a 12V system (your car's battery is the only thing that's 12V)... you have to have a HIGHER voltage output from the alternator in order to charge the battery. thus, when a car is running, they run from about 13.6 to 14.8 volts. 14.4 is the "standard" voltage for an alternator. some are a bit more, some are a bit less.. but ALL are over 13.5V. the battery just won't charge otherwise.
as for why companies spec their amps at different voltages (soundstream rates theirs at 12 and 14.4V).. Is due to industry standards and the amplifier itself..
there's no real set method of listing power output, except that they should list the system voltage, outputs power, frequency response, and THD at that output level.
there is no real standard to define what voltage or distortion they should run the amps up to though. some companies run the amps at 12V and very low distortion, and have lower numbers than what they put out in real world conditions.
Other companies drive them to huge amounts of distortion (clipping) and give them tons of drive voltage, so that they look like they put out a bunch of power.
Then there's the issue with regulated and unregulated power supplies inside the amps..
an amp with an unregulated power supply will put out more power if you give it more voltage. (i.e. one particular soundstream amp put out 50x4 at 12V. It put out 75x4 at 14.4V).
Amps with highly regulated power supplies won't change their output if you change the input voltage. PPI rates the output on their amps from 9 to 15V...
Old Mar 28, 2002 | 05:24 AM
sportscarboy715's Avatar
14.4 volts means the higher it is the less distortion you will hear, liek the gnine will make a Buzz or squealing sound if you have an amp that is less than 10 volts. a 14.4 volt amp is probably good but higher is better, the higher u go you may need to get a beter alternator and maybe a 6 volt car battery as an auxillary to help pump out the power
Old Mar 28, 2002 | 07:38 AM
jmax
Dude, if you don't know the answer, quit responding. If you have questions go ahead and ask. We are willing to answer.
And the 14.4 volt numbers are a marketing tactic. The unfortunate side of american capitalism.
Old Mar 28, 2002 | 08:19 AM
soundmike's Avatar
Very sound, Mike
For the same reason some people sell home audio (all-in-one) systems and computer speakers rated at PMPO instead of RMS. It's a marketing tactic that unfortunately always fools the consumer at one point or another.
Alpine V12's and JBL Pro's (as well as several others) are rated at 12volts. US Acoustics are rated at 11 if i remember correctly, so you actually get more power out of these systems once the engine is running.
Old Mar 28, 2002 | 09:55 AM
Your Car is Awesome, my fav year is '94 GXE- 5speed.....
Old Mar 28, 2002 | 02:46 PM
amax935's Avatar
dude
His car is awsome and everybody is a newbie once but there is no such thing as a 94 GXE 5 Speed unless someone did a tranny swap..
Take some friendly advise and read up before posting or you'll have all kind of jerks jumpin all over you.
Old Mar 28, 2002 | 05:51 PM
ZIPPIN's Avatar
Mauja He Mauja
doobadoo
Aug 15, 2015 06:43 PM
bassmann
Aug 13, 2015 10:13 PM
mark w chrzanow
May 23, 2002 08:17 PM
ejj
Nov 4, 2001 09:27 PM
Dave B
Oct 8, 2001 09:41 PM
