Rockford Fosgate amp
Old Nov 26, 2000 | 05:38 AM
Nathan's Avatar
I was looking for a Rockford Fosgate amplifier around 100-150 watts. I want to run one JL12W0 sub. Here's my question, what is the difference between a 1 channel and a 2 channel amp? Would you suggest buying a 1 or 2 channel amp to run 1 sub, and why? Thanks.
Old Nov 26, 2000 | 07:24 AM
Micah95GLE's Avatar
The mono amps that you are looking at are designed to run at 2 ohms for peak output. If you are going to get a 12W0, then you would want a two-channel (of the same price) bridged mono, and you'll get more power. Make sure that you get a 12W0-4 to get the most output. You can run the 12W0 with the Power 200a1, but you'll get more power with the Punch 250a2 bridged mono, for less $.
Old Nov 26, 2000 | 09:11 AM
Yellowbrother's Avatar
fosgate punch and power amps are different. punch amps are good but their sound quality is no where near power amps. power amps has more clarity. more power doesn't necessarily means better.
Old Nov 26, 2000 | 10:22 AM
Micah95GLE's Avatar
There isn't that much difference, and for a sub, SQ of the amp means very little. Power is the most important thing for subs.
Old Nov 26, 2000 | 10:39 AM
Nathan's Avatar
What is the peak power of a JL 12W0-4 subwoofer?
Old Nov 26, 2000 | 10:46 AM
Micah95GLE's Avatar
JL Audio rates it at 125 watts, but they always underrate their subs anyways. Plus, having more than enough power is always good. One reason is that the amp won't ever be overworked (and shut down or create distortion) if there is plenty of headroom. Also, you aren't likely to blow the sub up with more wattage than is rated. An amp doesn't produce its peak output all of the time, so the amp won't be sending a huge amount of wattage for normal listening volumes.
Old Nov 26, 2000 | 11:19 AM
Nathan's Avatar
I was also considering purchasing an Audiobahn A2200e 200watt amp because I don't have that much money to spend. How is this amp compared to a Rockford Fosgate 100z2 100watt amp?
Old Nov 26, 2000 | 02:14 PM
Micah95GLE's Avatar
Both will get the job done nicely. The Audiobahn makes more power, but it's a little bit more expensive. For the money, you'd probably be happy with the RF and the 12W0-4.
Old Nov 26, 2000 | 02:43 PM
Nathan's Avatar
Are the Audiobahn amps better quality than the RF Punch amps?
Old Nov 26, 2000 | 04:45 PM
Micah95GLE's Avatar
In my opinion, yes. RF's quality has gone downhill over the last few years, largely due to the fact that they signed a mass-production deal with Best Buys, and their production and R&D quality hasn't kept up. Audiobahn is fairly new, but their equipment has performed well on bench tests, especially for the price. Another good but inexpensive brand is Crossfire. Take a look at the TEK35.2. It will work well for your application, and is a very good amp for the money. I can quote specs from a bench test on that amp if you want.
Old Nov 27, 2000 | 06:46 PM
Brandon90gxe's Avatar
Nathan how much around are you looking to spend, because i want a system too and the equiptment your looking for is like the same thing im looking for, yet i dont konw how much any of that specific brands you mentioned cost. Basically, how much will the items mentioned above cost?
Old Nov 27, 2000 | 09:28 PM
Nathan's Avatar
Go look on ebay and they have great deals or new on used stuff. I am getting most of my stuff off ebay but teh only downfall is that I have to pay extra for shipping to Canada. Right now I don't know exactly how much I will spend.
Old Nov 27, 2000 | 10:12 PM
well thats the thing, i lok on ebay and i see hella good deals, but i dunno if its good stuff or crap. like they are all names ive never heard of before and stuff...
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
