Car Audio Question...
Old Sep 2, 2000 | 01:01 PM
Ants97SE's Avatar
I took apart my dash to throw in my Pioneer DHEP-4000 Headunit to replace the stock one and on the antenna connector there are two prongs instead of the one that goes into the Pioneer antenna plug. Am I gonna have to go out and buy an adapter for it? Can anyone tell me what I'll need? Or is there a way around this? Thanks.
Old Sep 2, 2000 | 01:22 PM
adam714's Avatar
Antenna Adapter
crutchfield sells the adapter for $9. the part # is 12040NI10. While your at it you shold probably get the wiring harness as well, for $8. the part # for that is 120707550
Old Sep 2, 2000 | 01:29 PM
deathwish's Avatar
Or just go to your local best buy/circuit city/hh greg/whatever and save yourself shipping cost and time
Course, they're still a rip off, those things have about a 1200% markup on them...
Old Sep 3, 2000 | 03:26 AM
NightRider's Avatar
Yeah, you have to get an adapter or else the new head unit will not work.
Old Sep 3, 2000 | 07:36 AM
mingo's Avatar
ground
instead of wiring the ground into the wire harness, just ground the deck to a metal peice somwhere behind the dash. it'll work better (dunno how and y) i think it'll reduce engine noise. fry's also has the wire harness. might have the antenna adapter too.
Old Sep 3, 2000 | 08:02 AM
Ants97SE's Avatar
Thanks guys, I went to Circuit City...
and found the adapter... didn't want to wait on Crutchfield again. I got the Unit in and it sounds great... now to wire up the subs...
Old Sep 3, 2000 | 08:28 AM
mingo's Avatar
in case u wanted help
if you plan to get aftermarket speakers and amps, you should run a 4ch. rca up to the front along with your 2ch sub rca. run the rca throught the center of the car, beneath the centerconsole carpetting. run the power on the side of the car. that way you'll avoid engine noise. the reason for running the 4ch. rca is so that you won't have to run cables again. tape up the end up the 4ch rca's so they won't touch ground. wrap them up individually then wrap them all together for neatness. then when u decide to get amps and speakers you can just plug em' in. also run wires for your speakers along with the rCA. hide all the wires under the dash somwhere and when you're ready pull em' out from behind the dash. (that means u gotta hide it where you can reach but not see, give it alotta slack) oh yeah also remember to run your remote wire to turn on your amps.
Old Sep 3, 2000 | 08:58 AM
adam714's Avatar
Re: Thanks guys, I went to Circuit City...
do the aftermarket stereos fit flush in the dash like the factory stereo? or does the removeable faceplates stick out a little
Old Sep 4, 2000 | 05:36 AM
mingo's Avatar
flush mount
i flush mounted my deck. they stick out about .25" u gotta either grind the existing hole to push the whole unit back. or you can drill new holes. drilling new holes and using spacers would help alot better. you need the spacers because the factory dash mounting points go in, making the screws too short to securely mount the deck with the new holes.. sounds confusing but.. if u get the point the cool
Old Sep 4, 2000 | 07:49 AM
adam714's Avatar
I understand. that's exactly what i needed to know. i had to do the same thing in my wifes villager
Old Sep 4, 2000 | 07:55 AM
PIONEER's Avatar
4000 Not a bad piece
Shouldn't cause any engine noise. has a filter built..
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Aug 12, 2015 06:39 AM
Slamrod
Aug 10, 2015 12:33 PM
MikesChevelle
Aug 9, 2015 11:50 AM
