Remote Reprograming Problem!!!
Old May 15, 2002 | 09:08 AM
bbrown's Avatar
I know this has been talked about but I can not find a thread in search for it:
I bought a 95gxe and it did not come with a remote with it, I bought a remote with reprograming instructions that works for maxima models 95-99, while inserting and removing the key[ten times within ten seconds] into the ignition, my hazard lights are not flashing at all. I have tried this many times, with no luck.
why is this not working?
Old May 15, 2002 | 09:23 AM
MaximaRacer's Avatar
Re: Remote Reprograming Problem!!!
Insert and remove ten times? I think you are supposed to turn the key to on then off 10 times
Old May 15, 2002 | 09:45 AM
bbrown's Avatar
Re: Re: Remote Reprograming Problem!!!
It actually says "insert and remove the ignition key from the ignition more than six times within 10 seconds".
been there, done that.
hazard lights still won't flash. what's up with this??!!!
Old May 15, 2002 | 01:37 PM
Gary95's Avatar
From what I recall, you need to make sure you've locked your driver's door with the lock switch, THEN put the key in and out ~10 times. The hazards would flash at that point.
Oh, just for the helluvit, do you have an LED indicator labeled "Security" mounted just below your gauge cluster? If not, you don't have an alarm (I think the base GXE didn't come with one).
If you're certain you have an alarm, then check the fuses. Otherwise, you may have a faulty alarm and will have to replace it (the cost of repair would be almost as much as getting a newer, BETTER alarm).
Old May 15, 2002 | 01:38 PM
Gary95's Avatar
From what I recall, you need to make sure you've locked your driver's door with the lock switch, THEN put the key in and out ~6 times quickly. The hazards would flash at that point.
Old May 15, 2002 | 01:57 PM
bbrown's Avatar
well I do not see the LED indicator which leads me to believe it did not come with a remote.
Old May 16, 2002 | 04:03 PM
Gary95's Avatar
well I do not see the LED indicator which leads me to believe it did not come with a [alarm].
Hey hey, you're making the forum wet.
Actually, the stock alarm is rather mediocre. Many people have replaced them. That gives you an opportunity to start fresh. I'll bet the car comes pre-set for an alarm module to plug right in. Should be rather easy to get one. Make sure you take advantage of things like auto window rolldown, dome light control, etc.
Old May 17, 2002 | 06:32 AM
bbrown's Avatar
thanks
I feel better already. I will look into a different alarm for my max.
Any suggestions as to what would be a good with auto window roll down and dome light control etc? how about the cost?
Old May 17, 2002 | 12:08 PM
Gary95's Avatar
There are several good alarms out there. Your best bet is to search the forums on aftermarket alarms. There's plenty of chatter about it, and you'll learn a lot from what's posted. Good luck.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
jerrod99_se-l
Sep 19, 2015 06:54 AM
flu2000
Sep 14, 2015 12:34 PM
mix master
Sep 7, 2015 08:28 PM
intimidator
Sep 5, 2015 07:23 PM
