Amp location ideas...
Old Jun 6, 2002 | 07:28 AM
mr_elotoe's Avatar
Diznatin Mizaxima.org Mizember
..where can I install my amp so its not in plain view every time I open the trunk. I've consider inside the trunk in the paneled area where the car jack is. Any suggestion on how to do this?
Old Jun 6, 2002 | 08:30 AM
mr_elotoe's Avatar
fixed my pic....bumpski
Old Jun 6, 2002 | 10:40 AM
Redmax's Avatar
Redlinemax Owner
what kind of amp is it? shoot i was going to install my amps where the spare tire was and its too long. Are your seats power?
Old Jun 6, 2002 | 10:54 AM
blizz20oma's Avatar
I'm so hood
Make sure your amp is efficient enough that it doesn't overheat if its tucked in somewhere with little ventilation.
I don't think I'll have a choice with my amp - have to mount it as close to the passthru window as possible, and keep the window open probably, lest I start going nuts with 12v fans.
Old Jun 6, 2002 | 11:11 AM
MaxSport730's Avatar
i just mounted a rockford fosgate 300s in my trunk....i had the same problem as you...no freaking clue where to put it but this is what i did
on the left hand side there's an indentation in the liner...what i did was take a piece of wood and screwed it onto the metal behind the liner to the RIGHT of the hole...then i cut a slit through the liner and had the wood stick out covering the hole...i mounted the amp on that...the wood is held on by about 5-6 screws and its very sturdy...i had to use a rotor and some creative measurments and drllling to make it flush but its perfect...the wood is painted black so it blends in with the trunk and the amp...all the wires are hidden behind it and it looks really good...its off to the side and bit elevated so it won't get damaged unless i carry a trunk full of baseball bats and it gets great ventilation...i've gotten many compliments on how clean and "professional" it looks
if you're interested let me know and i'll try to take some pics of it
later,
adrian
Old Jun 6, 2002 | 12:50 PM
mr_elotoe's Avatar
Very interesting ideas...there is a nice groove on the left side of the trunk that would fit nicely. The amp is a Kenwood 729s powering an infinity reference 10" sub. My goal is to make the trunk appear unaltered as much as possible. IOW hide the amp & camouflage the sub.....
-MaxSport730, I'd like to see a pic of your install. This would really help me visualize the setup.
Old Jun 6, 2002 | 03:02 PM
mr_elotoe's Avatar
How 'bout adding an rocker switch in the cab to power on/off the amp & maybe the PD2 without powering off the radio????? Anyone??? Anyone???
Old Jun 6, 2002 | 03:24 PM
ok...i've shot the pics with my friends digital camera...they are now on my hard drive as jpeg's...if you can tell me what to do now i'll show them to you...but i don't know how to post pics
i can either post them or just email them to you...i don't care
later,
adrian
Old Jun 6, 2002 | 04:25 PM
dm7297's Avatar
later,
adrian
this is how i did it too, i think this is the best spot
Old Jun 7, 2002 | 04:48 AM
mr_elotoe's Avatar
later,
adrian
E-mail is fine with me...Thanks, Homeskillet.
Old Jun 7, 2002 | 06:30 AM
blizz20oma's Avatar
I'm so hood
Maxsport - would you mind emailing them to me as well? jonak1@***.net
I appreciate it!
Old Jun 7, 2002 | 07:44 AM
Punch84's Avatar
I have my amp hanging upside down from the "rear dashboard". I just drilled holes into the metal and used 4 sheet metal screws. You cant see it unless you actually lay down in my trunk.
Old Jun 7, 2002 | 08:02 AM
i was thinking about doing that but the instruction that came with the amp (rockford) said explicitly that you shouldn't hang the amp upside down...amps should only be mounted face up or vertically
just FYI
later,
adrian
Old Jun 7, 2002 | 08:18 AM
Punch84's Avatar
Yea, I read that too. (I have a RF 160.2) I just ignored it and did it anyway. I dont push it too much so it still gets air.
Old Jun 7, 2002 | 11:36 AM
mr_elotoe's Avatar
I've considered building a 'cradle' and mounting it under the rear deck in the trunk so that it not upside down but still out of sight.
Old Jun 7, 2002 | 06:12 PM
PATRICK94SE's Avatar
Heat rises, The heat sink might feel cool but that would only be because it is all rising up and being absorbed by the circut board.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
sliptap
Sep 30, 2015 05:57 AM
