Subwoofer + amp Setup help
Old Jun 13, 2002 | 11:43 PM
abnorm's Avatar
My Subwoofer has been setup with a 4 channel Hifonics amp in the trunk a while back and I don't think it's been bridged correctly. How do I tell if it is and I'd like instructions on how to set it up right.
My subs are two 12" in a sealed box hooked up to a 4 channel Hifonics amp (50W RMS X 4).
Thanks!
Old Jun 13, 2002 | 11:57 PM
nismo240sx's Avatar
so youre running 2 channels to each sub?
if so, you should have 1 sub hooked to one pair of channels, usually in the L+ and R- fashion...the positive going to the + and the negative going to the -. the other sub should be hooked up the same way.
eric
Old Jun 14, 2002 | 06:20 AM
time2reup's Avatar
If you want your amp bridged you need your subs run in parallel. Both positives wired together, both negatives together, and then you should have a bridged pos and a bridged negative on the amp, plug n play. Make sure that your amp is stable at whatever load you are showing it. If you have two 4 ohm subs wired up this way the amp sees a 2 ohm mono load.
Apr 16, 2020 05:15 AM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
