Installing dual 10s and an amp
Old Jun 20, 2002 | 07:48 AM
Junior P Zilver's Avatar
hi guys,
i own a 2002SE no bose! I will be installing 2 10s and an amp. my question is does the stock HU have rca inputs or outputs? or will I have to do splices from the speaker out puts?
Thanks for you help.
Sincerely,
Junior Padilla
http://www.holyrollerz.com
Old Jun 20, 2002 | 06:38 PM
maximadave's Avatar
detailerdaveb@gmail.com
Re: Installing dual 10s and an amp
Originally posted by Junior P Zilver
hi guys,
Sincerely,
Junior Padilla
Factory decks do not have rca preamp outputs. If you stick with your oem deck you will need to find an amp that accepts speaker level inputs and tap into the rear speaker leads.
Old Jun 22, 2002 | 12:01 PM
Bad97MaxSE's Avatar
thats what I did and ive had no problems.
Old Jun 22, 2002 | 09:15 PM
Just go 2 kicker 10 w/an old jensen amp. connected it with the stock HU sounds pretty good. My next investment will be component speaker.
Thanks guys,
J.
Old Jun 22, 2002 | 11:33 PM
Pearl96Max's Avatar
I tend to get a bit irritable
NO factory radios have preouts. Use either an amp that accepts speaker inputs or a "high level convertor" which will convert your speaker leads to RCAs, which on occasion depending on the one that you use and if adjustable made distort sound if not adjusted properly.
MaxLife17
Jun 27, 2019 01:37 PM
popdedop
Sep 11, 2015 11:17 AM
Justin Kroll
Sep 2, 2015 11:06 AM
