Bose questions?!?
Old Jul 3, 2002 | 12:08 PM
magnetik's Avatar
Bose questions?!?
I am not going to bore anyone with the same old Bose questions... but I have replaced my BOSE headunit with an Alpine 7894 with a BOSE interface adapter. If I bought new component speakers... couldn't I just remove the BOSE interface adapter and just use the normal "non Bose" harness and plug it right in and power the new speakers with the deck?
Old Jul 3, 2002 | 12:16 PM
H.N.I.C.95's Avatar
Correct
Old Jul 3, 2002 | 12:21 PM
magnetik's Avatar
Thanks... I was hoping that would be the case...
final question.. I understand that the factory BOSE speakers have a proprietary connector.. I assume that I would only use + and - connections... and not use the extra wires such as "power" etc... you don't happen to know where I could find out which ones are + and -?
Old Jul 3, 2002 | 12:29 PM
H.N.I.C.95's Avatar
trial and error
Old Jul 3, 2002 | 02:29 PM
blizz20oma's Avatar
I'm so hood
maybe a wiring diagram in a FSM would help out. I was a little boggled when I glanced at the connectors/wiring of the factory amp/speakers - none of the wires in the amp harness even matched the color up front for front +/-
If I was you, I'd just run all-new wire in the case of powering replacement speakers with your alpine hu anyway. If I was able to do it, anyone can
Old Jul 25, 2002 | 09:51 AM
BLACKIE's Avatar
Skinny
They are the skinny wires on each speaker that you take a loose. After you cut them just extend them to your new speaker and you will be good to go. Holla
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
popdedop
Sep 11, 2015 11:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
