Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Dash Kit vs. Painting Dash
Old Jun 30, 2003 | 04:51 AM
bohemian_bomb's Avatar
Who has seen or done one or both?
Experiences?
Is it hard to mess up painting your dash? Do the dash kits crack or fade? Stuff like that...
Pros and cons of each? Installation, etc? Should dash kit be done professionally?
I'm looking to do one or the other and need some advice.
Thanks!
Old Jul 2, 2003 | 07:53 PM
greg82's Avatar
I recently painted the trim in my dash. It's real easy, just remove the trim pieces, scuff lightly and coat with primer, then paint and then clear coat. The only thing to watch for is accidentally cracking the pieces. Another thing is the top two vents in the middle. Take the trim out real carefully to keep the louvre-type plastic thing inside the housing, it's a ***** getting them back together.
greg
Old Jul 30, 2003 | 12:59 PM
youngbleek85
Painting interior
Wuts up, i took out all of my interior peices that i wanted to paint and i was wondering what you meant when you said scuff the pieces. And also how many layers of paint did you put on the peices and did you put primer on after each layer. And do u have any pics?
Old Jul 30, 2003 | 01:37 PM
Y2KSESteve's Avatar
Scuff them up to help the paint stick i.e. light sanding.
Old Jul 30, 2003 | 08:33 PM
youngbleek85
HOW MANY COATS OF PAINT TO USE
When i paint the interior should i paint it more then once. I was told that i should put the primer on and then the paint. And then let it dry and paint it again. And that i should do that 8 or nine times to each peice. I dunno if that is the right way to do it. Can sokmeone give me steps on how to do it so it comes out looking Great. Please can somebody help me.!!!!!
Old Jul 31, 2003 | 08:14 PM
greg82's Avatar
Re: HOW MANY COATS OF PAINT TO USE
Take out everything you would like to paint, find a VERY fine grit sandpaper and scuff the surface. It must be fine so you don't get big nasty scratches in the trim. Primer, 2 coats. As for paint, 2-3 costs should be ok, unless you feel you need more. I used a clear acrylic coating to finish each piece. I only used 3 or 4 coats and I am happy wiht the results. This is up to you, do 10 coats if you want.
I promise I'll post pictures soon on my Cardomain site.
greg
Old Aug 2, 2003 | 11:22 AM
CheshireCat76's Avatar
If you're going to paint it I would go with
the G2 interior carstyling sprays. Good stuff.
http://g2usa.com/interior.shtml
Old Aug 2, 2003 | 08:50 PM
youngbleek85
I just painted my interior for the first time and it came out nice as hell. If any body wants any advice just let me know. Here is a link to my interior page.
http://forums.maxima.org/showthread....4&goto=newpost
Old Aug 10, 2003 | 11:29 PM
zemp68's Avatar
So this painting method is better than and cheaper than the stick on applications??? There are no cracks or chips? Doesn't fade with heat?
Old Aug 11, 2003 | 08:23 AM
youngbleek85
Yeah it is really good. Just make sure that you coat the surfaces at least 3 times. When i say that i mean spray paint it and let it dry. and then spray paint it again. And keep on repeating this.
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
salty318
Sep 29, 2015 01:21 PM
