Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
getting bugs off
Old Jul 8, 2003 | 02:36 PM
Tallboy007's Avatar
Getting Bugs Off
Hey,
What is the best way to remove bugs from the front of my car? Soap and water can only do so much. Any suggestions?
Old Jul 8, 2003 | 02:48 PM
Y2KSESteve's Avatar
Try a bug and tar remover.
Old Jul 8, 2003 | 03:02 PM
PrinzII's Avatar
OG and counting...
Also, you might want to try claying to get rid of the bugs that the remover left behind.
Old Jul 8, 2003 | 04:29 PM
Bluesbrekr's Avatar
Doctorate in Detailing
Doesn't the bug and tar remover take the was off too?
Old Jul 8, 2003 | 07:08 PM
Dave Holmes's Avatar
1500 grit sand paper, works every time Just kidding. A safe alternative is pure car wash shampoo. Or if they are really stubborn (baked on for awhile), bug and tar remover. Whatever you use, let it soak a few minutes, letting the chemicals do the work instead of scrubbing which will cause scratches or swirls. Just put wax on after because it will remove the wax. Polishing before the wax would be good to put back the oils that are stripped, too.
Dave
Old Jul 9, 2003 | 03:01 AM
SilverChrome03's Avatar
Prep is the key here as well. Make sure that you have a number of coats of wax on the front end of your car. A bit of work now, but this will help in bug removal later.
Wash your car with warm water and car wash shampoo and let soak for a minute like mentioned above.
This should elp in removing bugs from your front end.
Bob
Old Jul 27, 2003 | 06:04 PM
SLVR99MAXSE's Avatar
Re: Getting Bugs Off
Originally posted by Tallboy007
Hey,
WD40 works extremely well on bugs and road grime. The way I do it is:
1) Water down the surface.
2) Spray WD40 on the bugs/road grime
3) Let the WD40 stay on there for a couple of minutes.
4) Using a damp terry towel, gently wipe the surface clean of the contaminants.
5) Depending on how badly the bugs are concentrated, a second application of WD40 may be needed.
Works for me.
JoshG
Sep 5, 2015 10:10 PM
gregulator
May 26, 2001 11:04 PM
2K1MaximaMan
May 11, 2001 02:16 PM
VQ Quick
May 10, 2001 11:35 AM
seanqlee
Apr 28, 2001 11:38 PM
