Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
what step to apply the paint?
Old Apr 10, 2004 | 06:32 PM
pjalst
I'm going to detail my car using only 3 steps( I'll add more steps when I get a Porter Cable). I'm going to ClaY, scratch X and then Wax. I also have some chips in the paint on the hood. I want to use some touch-up paint on the chips, but I don't know At what step to apply the paint. Do I do it after claying, scratch X or Waxing? Or, do I do it before Claying?
Old Apr 10, 2004 | 09:37 PM
crappopotamus's Avatar
im doing a similar thing. i ordered some langka, which smooths down a lumpy touch up job. heres my plan.
clean (rubbing alcohol)
touch up
langka
scratch x
wax
Old Apr 12, 2004 | 05:08 AM
pjalst
where you get the langka?
Old Apr 12, 2004 | 06:16 AM
Bluesbrekr's Avatar
Doctorate in Detailing
IIRC, Scratch-X is pretty abrasive. I'd only use it if your entire car is in bad shape. I'd also recommend using a less abrasive polish after the Scratch-X, then wax.
I've used it on some bad scratches and noticed it dulled the clearcoat. I used a less abrasive polish after that which brought the shine back.
Old Apr 12, 2004 | 10:31 AM
pjalst
I've got a lot of swirl marks all over
Old Apr 17, 2004 | 06:53 PM
pjalst
Can someone recommend a less abrasive polish?
Old Apr 18, 2004 | 02:57 AM
Bluesbrekr's Avatar
I'm partial to Menzerna polish. It's used in the factories of BMW, Mercedes and GM. There are 2 grades, Intensive and Final. I believe both are less abrasive than Scratch-X. I've had very good luck with them.
Old Apr 22, 2004 | 08:58 PM
Bman's Avatar
Scratch-X isn't that abrasive. It's certainly not as strong as a fine cut cleaner/compound. It's probably somewhere in between a swirl remover and fine cut since they want it to be able to (somewhat) deal with swirls and light scratches, but they don't want it so strong that people might get into trouble using it since it's only a retail consumer-level product.
Less abrasive is a swirl remover, but if you have it already and are doing this only by hand at the moment, Scratch-X isn't a bad place to start I think.
I'd use touch up paint after claying but I don't think it makes all that much difference. Just make sure to clean the spot with some solvent first.
Old Sep 13, 2004 | 12:06 PM
spirilis's Avatar
I'm having this same question... wondering what the best way to apply touch-up paint is for maximum protection. For now, I applied it after a wash, so it's presumably on top of the wax. DAVEB suggested over the phone to use a cotton swab with rubbing alcohol or something... I'm presuming the goal is to get the wax off the area. I think my best procedure would be to remove the wax from that area, apply the paint, let it dry for a day, then polish/wax that area to blend in the touch-up paint (i.e. meguiar's 3-step process). Any thoughts?
Old Sep 13, 2004 | 04:37 PM
99se5spd's Avatar
http://www.langka.com/newsite/index2.html. Langka is good stuff. and scratch-x is wonderful ive use that all the time, does wonders on old paint with an orbital.
Old Sep 15, 2004 | 09:58 PM
hadman's Avatar
Wash the car.
Preferrably remove any old wax.
Add the touch up paint.
Polish .
Wax.
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
gigabyte
Jan 6, 2017 06:05 PM
