Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Gunk engine cleaner
Old Aug 16, 2005 | 12:26 PM
GoldMax99's Avatar
Gunk engine cleaner
Do you guys recommend this product for cleaning engines? It states on the can to cover up any plastic/rubber components or wires. This seems like a lot of work, do you have to do this? As long as I aim the can at the actual engine block wouldn't that be enough.
Old Aug 17, 2005 | 01:29 PM
GoldMax99's Avatar
Bump
Old Aug 23, 2005 | 06:58 AM
aminus21's Avatar
when I used it, I just covered my alternator with a plastic bag. I also tried not to spray in the spark plug area, and around the distributor. worked good for me.. u might also wanna use CD-2 engine detailer afterwords.
Old Aug 24, 2005 | 06:41 PM
GoldMax99's Avatar
thanks for your help. i used brake cleaner around the belts/alternator and that worked fine for that area.
Old Aug 25, 2005 | 01:34 AM
max723's Avatar
i just took off my intake and covered the tb with a bag and rubber band. then removed the battery and soaked everyting for about 10 min. brushed, hosed down. then repaeat. do this once and again in a month and you should have a spotless engine.
shilov
Feb 19, 2024 09:40 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
