Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
plz help am i screwed????
Old Jun 21, 2006 | 06:53 PM
krmaxima's Avatar
well i curbed one of my rims so today i started to fix the problem but i might have made it worse. FIrst i took 600 grit sandpaper and sanded the polished lip and the curbed part of the rim. then i started to polish with a metal polisher however the rim is not shinny as it was before. Am i screwed or do i have to do something else.
please help me
oh yea i have the axis mod7 rims with the polished lip
thanks
Old Jun 22, 2006 | 02:57 AM
Bluesbrekr's Avatar
Doctorate in Detailing
You'll need to use finer sandpaper. 600 is pretty abrasive for a rim. Get some 800, 1000, 1500 and 2000. Using those ought to bring back the shine. It did on my polished lip.
Old Jun 22, 2006 | 04:53 PM
krmaxima's Avatar
what kind of rim do u have i guess my axis mods have a clear coat so i think im pretty much screwed
Old Jun 22, 2006 | 06:47 PM
jlars205's Avatar
How bad do they look? Can you post a pic? Because if it doesn't look too bad you COULD do the same to the others to match the one you messed up. But like I said, I don't know how bad this one looks. If that's not an option you like, I would look for someplace to re-finish the rim for you professionally. My .02
Old Jun 22, 2006 | 07:38 PM
gec
600 definately to rough for wwhat your are attempting...safe with 2000...I know you used the metal polish, but try some spray glaze on it and see if the result improves.
Old Jun 22, 2006 | 09:26 PM
krmaxima's Avatar
thx for the help well the reason why i used the 600 was because of the curbed part. well i polished it again but axis is telling me that since it has a clear coat it will be imposible to get the shin back. so i think im just going to get it re done. only 100 dollars and they fix the curbed part of the rim. i think its a good deal
Old Jun 27, 2006 | 04:01 PM
krmaxima's Avatar
well i sanded the whole lip with 600 than 1000 1500 and then 2000 and then polished it. well since it doesnt have a clear coat now should i get it clear coated to lock in the polished lip???? oh yea it looks good now mb shinnier then the other rims.
Old Jun 27, 2006 | 05:28 PM
brainy's Avatar
nice recovery! or you could sand off the clear coat from all the other rims to match up?
I've seen soo many rims out there that the coat peels off anyway.
Old Jun 28, 2006 | 02:51 AM
Bluesbrekr's Avatar
I had to sand off the clear coat from all 4 of my rims because of salt damage. As I said above, they look great. The down side is that they need to be polished regularly to keep them looking good. Doesn't take that long but you have to take the time to do it.
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
jchronis2552
Sep 23, 2015 04:57 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
thenewguyy
Sep 12, 2015 11:12 AM
