Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Filter to prevent water spotting?
Old Aug 6, 2006 | 08:43 AM
MAXRB8's Avatar
Hey Guys, lately the chlorine levels in our water system here seemed to have been increased and unless I use a chamois (shammy?) after every wash I have these nasty white water spots. Does anyone have a remedy for this? Such as inline hose filter? thanks
Black cars are a PITA to keep clean as it is without having to dealing with water spots!
Old Aug 7, 2006 | 12:21 AM
filtor1's Avatar
The chlorine content has nothing to do with the water spots. It is the dissolved mineral content that leaves the spots. A water softener would cut way down on the water spots but not totally as softeners do not remove all of the impurities in the water. I recommend using some method of getting the water off of your car after every wash to prevent any build-up on the surface. I used to get free deionized water while I worked in industrial water treatment and miss it very much. All I had to do was rinse and walk away. Come back an hour later and no spots. One of the things I miss about my old job.
Old Aug 7, 2006 | 12:22 AM
Bonka's Avatar
Schnell kaputt
There are inline cannister filter systems available. I think Autogeek has everything you need for it. I would probably check Home Depot first to see if they have something that you can use strictly for your outdoor water system.
Old Aug 14, 2006 | 07:41 AM
MAXRB8's Avatar
Hey Thanks Bonka, what do you do? Shammy?
Old Aug 14, 2006 | 08:39 AM
ecks's Avatar
I piss on Civics.
there are two things you can try..
1. mr clean auto wash system.. the gun you get sprays a regular water rinse, foamed soap wash, and has a deionzed water setting.. it works with a PuR water filter.. 20 bucks.. totally worth it..
2. after you wash your car, rinse it with the spray, then take off the sprayer, and let the water roll off on the car at like decent angle.. that water will sheet most of the existing water off leaving you with barely anything to dry off
if you have any issues or need to see #2 in action... www.meguiars.com... check out the videos section
clh288's Avatar
Make sure to dry your car with a towel
Old Aug 14, 2006 | 03:12 PM
Bonka's Avatar
Schnell kaputt
I blot excess with microfibre or plush terrycloth towels.
I wash and rinse my car off with hose only (no nozzle) so water dropplets don't accumulate. It tends to sheet off the car and whatever remaining water puddles are blotted dry. I also wash during the evening out of direct sunlight so water doesn't have a chance to dry on the paint surface.
Old Aug 22, 2006 | 11:36 AM
E55AMG2's Avatar
Wat
The easiest way to not have your car spot while washing it (regardless of color)
1) Wash in the shade AND dry in the shade
2) Wash top to bottom using a high quality soap
3) Use a nozzle with a "shower" setting, this way you get the sheeting action as well as water beads to break up anything stuck on the surface
4) Use a water blade to dry the majority of the car, then touch up with a high quality (and clean) chamois or High quality waffle weave towel (again, make sure its clean and has been washed WITHOUT any fabric softener)
4a) Use wax as u dry (nice for washes in between waxes) with a clean high quality chamois, then follow with a clean high quality waffle weave towel
5) Crack open a beer (or beverage of choice) and marvel at your car washing genius
Old Aug 23, 2006 | 04:38 PM
MAXRB8's Avatar
I just hate using a chamois it's time consuming and I always have to wash the wife's minivan also, the Max being black I seem to have to wash the car every 2 or 3 days PITA, so I was hoping to find a filter system of some kind so I wouldn't have to dry the car. Last black car I had was a 300ZX TT and after I sold it I vowed to never own a black car again. ...... they just look so dam good though!
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
uttadms31
Sep 30, 2015 05:24 AM
