Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Dyno's for after the 00VI install and tunning...
Old Jul 13, 2005 | 06:27 AM
SDot82's Avatar
The dyno pic#1 is right after the 00VI install with no tunning at all and switch over point was at ~4800 rpms which gave me 200tq and 183 hp ...
The next couple of dyno's are when I went to tune with my VAFC 2.
Dyno pic #2 was the second run with very little tunning and the switch over was moved to 5200 rpms on the VAFC (but it lags about 200-300 rpms) which gave me 190 hp and 204 tq.
Dyno pic #3 and 4 was 5th run of the day 182 hp and 205 tq (car was getting heat soaked so I was losing hp) used same switch over.
Dyno pic# 5 and 6 was my last run of the day tuned my a/f to the best I could which gave me 183 hp and 210 tq and used same switch over.
Old Jul 13, 2005 | 06:30 AM
SDot82's Avatar
Old Jul 13, 2005 | 06:31 AM
Kevlo911's Avatar
Kevlo for President
Mustang Dyno
Need to get on a dynomax
I think your VIAS is broken, fix it.
Old Jul 13, 2005 | 08:07 AM
jmeister's Avatar
Hard to tell what's what by those pics. Wonder why the lines get so eratic after you start tuning?
Old Jul 13, 2005 | 08:14 AM
SDot82's Avatar
Yeah the scanner I used sucks. But the red line is the hp, the dark line (black) that starts out high in the beginning is my a/f ratio, and the dark line (supposed to be Blue) that starts out lower is my tq line. The numbers on the right in red are hp and on the left are for a/f ratio or tq. I think because this person did not smooth the graphs out like the first time I went.
Old Jul 13, 2005 | 01:11 PM
Nismo3112's Avatar
Custom User Title
Mustang dynos tend to dyno conservative.. Nice numbers.
Old Jul 13, 2005 | 01:30 PM
SDot82's Avatar
What's that mean I make more than what I should or less....
Old Jul 13, 2005 | 02:40 PM
DAVE Sz's Avatar
Hooooooonda.....
WHo knows, either way you won't know til you go on a real dyno.
Old Jul 13, 2005 | 02:47 PM
Kevlo911's Avatar
Kevlo for President
GO on a Dynojet.
Old Jul 13, 2005 | 07:09 PM
SDot82's Avatar
Ok I did some research on the whole mustang and dynojet. The person that works where I got my dyno said that it puts a load on the car(as if I were on the really on the street) so the hp/tq numbers are lower. Plus I found this on the web
The way a mustang dyno works is that it actually puts a load on the car, to better simulate real world conditions on the road. a dynojet measures power by how fast you can spin the rollers, without actually putting a load on the car. the concensious is that mustang dyno's are better tuning dyno's but will give you lower numbers. not saying that a dynojet is inferior its just that everyone needs to realize that a/f will be slightly higher when the car hits the streets, while the car actually has a load on it. if you want to inflate your ego get on a dynojet and stay away from the mustang dyno.
So I can deal with my numbers being a lower, if I really want to find out with out a load I will go to a dynojet. But from a formula (which is add 10-15%) i would put down about 209 hp and 231 tq using just 10%.
Old Jul 13, 2005 | 07:18 PM
Zack342's Avatar
that may very well be correct but for comparison to other dynos dynojet is your best bet.I would love to compare your dynos to mine but they are not dynojet so it would be comparing apples to oranges.
Regardless nice numbers, so HIt the TRACk and lets see how you can do.
Old Jul 13, 2005 | 07:21 PM
SDot82's Avatar
Yeah, I'm going to try and find a dynojet around here just so I can see what it will be. Plus I don't like how the scale their graphs.
Old Jul 14, 2005 | 08:08 AM
SDot82's Avatar
Back to my graph, when I changed my switch over point on the power valve I eliminating that ugly switch over dip and gained 7hp just from that.
Old Aug 3, 2005 | 01:48 PM
eckohb's Avatar
you're auto I take it? those are nice numbers. What are all your mods?
Old Aug 3, 2005 | 03:12 PM
SDot82's Avatar
I haven't had a chance to go to a dynojet yet (probably do it in the fall) but I'm a 5sp. Mods VI, VAFC 2, UP, and Y-pipe.
Old Aug 3, 2005 | 05:45 PM
eckohb's Avatar
Really? No ecu huh? Wow, nice TQ numbers. I assumed you were auto because of the difference between your tq and hp. What's the UP, UDP?
Old Aug 3, 2005 | 10:39 PM
SDot82's Avatar
Yeah motostorm underdrive pulley, nice mod for $90. Thanks for the complements I gained about 10 tq tuning with the vafc 2.
Old Aug 4, 2005 | 02:51 PM
eckohb's Avatar
nice. I gained 14 whp and 19 wtf from tuning with the SAFC-II. I believe next will be 5 spd swap for another 15 or so whp/wtq.
Old Aug 4, 2005 | 06:42 PM
SDot82's Avatar
Thats real good gains.
Old Aug 7, 2005 | 09:13 AM
Bobo's Avatar
Excuse my ignorance, but what is a SAFC-II?
Old Aug 7, 2005 | 11:31 AM
eckohb's Avatar
Super Air Fuel Converter 2
Old Aug 7, 2005 | 02:04 PM
Bobo's Avatar
That's great now what is that in English, ie. what does it do and how muchy?
Old Aug 7, 2005 | 05:17 PM
SDot82's Avatar
It basically can control your air-fuel mixture meaning you can gain more horse power and torque.
Old Aug 7, 2005 | 08:17 PM
eckohb's Avatar
my apologies, i figured perhaps you would have looked it up on your own or something. I said that in English, maybe its just your lack of understanding. With it, you can give/take air/fuel at every 200 rpm, making your A/F ratio produce the most hp/tq
Old Aug 8, 2005 | 08:25 AM
Stephen Max's Avatar
The Apexi SAFC is used to lower or increase the air-fuel ratio.
The SAFC intercepts the voltage signal from the maf sensor and either adds or subtracts volts to fool the ecu into thinking that the airflow into the engine is different that what it actually is. The ecu will then either increase or decrease the fuel injector duty cycle based on the altered maf signal.
If you are trying to lower the afr of an engine already running with 100% injector duty cycle, however, the SAFC is useless. In that case you have to increase fuel pressure to add more fuel. A better option is to replace your injectors with larger ones and use a piggyback or have your ecu reprogrammed for the larger injectors.
Another consideration is that the VQ30 ecu controls ignition timing using the maf signal, TPS setting and engine rpm. Using the SAFC to make a large correction to afr may have the unwanted result of changing ignition timing as well.
Old Aug 19, 2005 | 08:21 AM
Weimar Ben's Avatar
Helicopters! Money!!!
those dyno slips are kinda hard to read. If you would like, you can mail them to me and I can scan them and mail it back to you.
Old Aug 22, 2005 | 10:55 AM
suicidalspd99
Mustang dynos are bad. When your on the road you are putting less of a load than a Mustang dyno. Imagine the raod doing a burnout on your tires. That is kinda what mustang dyno is like. The road can not put a load on your car. I wil look for some better info. For you guys on this topic. But ne wyas some nice numbers with the vi.
MaxLife17
Jun 27, 2019 01:37 PM
t6378tp
Sep 29, 2018 04:27 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
