Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
new dyno after S/C 366hp, 310tq
Old Apr 7, 2007 | 05:57 PM
96sleeper's Avatar
All previous NA mods minus the underdrive pulley
V1 S/C kit with the 3.60 pulley at 6lbs of boost and stock stillen piping
clutchnet 6 puck and fidanza flywheel
deatschwerks 550cc injectors
JWT S/C ecu with 100 ocatne timing program
Z32 MAF sensor
1 step colder plugs
newly rebuilt VLSD tranny with PPG 3rd and 4th gears
Dyno was on 93 octane. Uncorrected numbers were higher.
The graph shows my best N/A 3.5 dyno also for comparison.
Old Apr 7, 2007 | 09:33 PM
streetzlegend's Avatar
Very very nice man. Your on a 3.5 right?
Old Apr 8, 2007 | 05:26 PM
95BLKMAX's Avatar
yes he is. Congrats man!!!
Old Apr 8, 2007 | 10:39 PM
ajcool2's Avatar
Wow I'm going to say your going to run a 11.3 at the track. Whens the next time your going?
Old Apr 9, 2007 | 03:56 AM
96sleeper's Avatar
I would like to go to the track soon, but I don't think it will be near that fast.
Old Apr 9, 2007 | 06:22 AM
meximax's Avatar
SC Overspinning Swapper!!
Welcome to the 4th Gen VQ35 SCed club Matt. Those are some very healthy numbers. I love the way those cams open up that high end.
Old Apr 9, 2007 | 06:47 AM
Stillen Maxima's Avatar
Pay to Play
Wow! congrats!!! Nice #'s.
Old Apr 9, 2007 | 08:33 AM
Kevlo911's Avatar
Kevlo for President
NICE numbers
Old Apr 9, 2007 | 11:54 AM
DandyMax's Avatar
3.5 in the works
Good work Matt. Looking forward to track times.
Old Apr 9, 2007 | 10:53 PM
Nealoc187's Avatar
SLOW
Very nice numbers matt. did you take a video?
lol @ 11.3
Old Apr 10, 2007 | 03:25 AM
MorpheusZero's Avatar
Awesome man, can't wait to see some video and some track times.
And yeah, not quite so sure that this is a mardi-beating setup.
Old Apr 10, 2007 | 05:03 AM
96sleeper's Avatar
lol @ 11.3
no, I wasn't able to take a video. I will try to get someone to take a video at the track when I go.
Old Apr 11, 2007 | 03:43 PM
jessea510's Avatar
congrats!! I love how the cams and modded IM open up the top end!! It shifts the curve about 500rpms to the right compared to meximax
Is the JWT retarding any timing or it does not since you are running 100 oct prog??
I bet at least a 11.8 seeing you ran a 8.09 (1/8) on your last run with only 272
Old Apr 11, 2007 | 05:03 PM
96sleeper's Avatar
I haven't checked yet, but the 100 octane program has gotten others around 18 degrees of max timing, whereas the stock ecu will do around 25?. The standard jwt ecu is crap and they program 10 across the board only...
Old Apr 11, 2007 | 06:06 PM
jessea510's Avatar
I think that is true because looking at MardiGrasMax timing from his 100oct jwt chip http://forums.maxima.org/showthread.php?t=453151 it only had 18 deg and from looking at stock timing http://forums.maxima.org/showthread....&highlight=map it is at about 24. Then MardiGrasMax was doing testing with 93 oct and he had no detonation. That means you can probably keep stock timing and still run reg pump gas without any detonation but mardi did have a fully built engine
The reason I ask is because you have cams and modded IM which meximax doesn’t have, so that means you should have more hp(maybe you should be at 390 with stock timing) even though you are only running 6psi and he has 13.
Also, with regular stock timing and maybe at 13psi you can be at PROBABLY 450 whp. However, you might not want to push your car and risk blowing up something
Old Apr 11, 2007 | 08:21 PM
Nealoc187's Avatar
SLOW
Hey matt did you run that dyno all the way out and touch the limiter? It looks like it ends at 6800. I'm about to cartest your numbers.
Old Apr 12, 2007 | 03:52 AM
96sleeper's Avatar
This ecu is supposed to be 7000rpm rev-limit too, but I didn't hit the limiter. I was trying to stop just short.
Old Apr 12, 2007 | 08:14 AM
C MAX's Avatar
car seems like its running very good. i dont know about 11 seconds lol, you'd need a little more hp but mid low 12's for sure congrat.
Old Apr 12, 2007 | 09:15 AM
96sleeper's Avatar
The car was good for a mid high 12 all-motor, I would like to run some low 12's or maybe a high 11 soon. This is almost 100 more hp than all-motor now, and it will b as soon as I get my supercharger CAI installed.
Old Apr 12, 2007 | 10:18 AM
C MAX's Avatar
good luck that would be nice to see, but it gets harder to squeak those seconds out after 12's,lol. sheesh it was easy getting to 12's but now im stuck,lol.
Old Apr 12, 2007 | 06:00 PM
Nealoc187's Avatar
SLOW
I cartested an 11.80 @ 116 with a 1.74 60'. I had your all motor times modeled very accurately and only changed power curve. So I say you could run 11.75-11.90 @ 115-117.
Old Apr 12, 2007 | 07:21 PM
96sleeper's Avatar
I checked cartest too, and came up with just about the same numbers. 116-117mph is what I saw, it just depends on how hard I want to launch it...
Old Apr 13, 2007 | 09:26 PM
CustomaX's Avatar
nice man the 3.5 is more powerful
Old Apr 14, 2007 | 06:47 AM
C MAX's Avatar
cartest,lol. put that b@#tch on the track thats the real truth.
Old Apr 14, 2007 | 12:53 PM
ajcool2's Avatar
Any 11 second car is a friend of mine. lol I just want to see a max in the 10's. We are so freaking close.
Old Apr 15, 2007 | 06:51 PM
Tatanko's Avatar
Bacon Lover
Close, but so far away if you think about it.
Here I am worried about being in the 14's
Old Apr 15, 2007 | 09:29 PM
gtr_rider's Avatar
192.168.1.1
wow nice numbers
Old Apr 16, 2007 | 11:40 AM
JClaw's Avatar
Awesome man I hope my NA curve looks like your 272whp run once I put the cams in and tune it.
Keep it low boost! It would be sooooo awesome to claim an 11.90@116 mph on a whopping 6 lbs of daily driveable boost.
Old Apr 21, 2007 | 06:23 PM
MaxObesset's Avatar
nice setup check pm got a question for you for a friend
Old Mar 2, 2008 | 10:18 PM
ajcool2's Avatar
lol @ 11.3
I was close.
Old Mar 5, 2008 | 12:31 AM
ptatohed's Avatar
Licensed to Spell
Z32 MAF sensor
1 step colder plugs
Hey 96, care to define "All previous NA mods"?
Good job man!
Old Mar 5, 2008 | 04:58 AM
96sleeper's Avatar
Good job man!
This is from almost a year ago, I have not re-dynoed at 9lbs or 12lbs yet.
My old N/A mods were:
Engine mods on the 3.5:
JWT hybrid intake
ported MAF sensor
70mm TB
A33 IM modded
JDM cams (same specs as JWT)
test pipe
2.5 inch electric exhaust cutout in test pipe
2.5 b-pipe
hooker muffler
JWT VQ30 ecu with 7000rpm redline
UR underdrive pulley
Spec stage 2 clutch/stock 4th gen flywheel
cattman headers
adjustable fpr
SAFC II/zeitronix WB02 tune
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
impossible2stop
Oct 28, 2000 11:31 AM
Nismo87SE
Oct 23, 2000 08:15 AM
JimW
Oct 9, 2000 05:28 PM
