Quote:
Seems like a contradictory statement considering your issue.Originally Posted by VqMoNsTeR
4.5 gens don't count. half of them can't get there swaps to run let alone cams. im actually having the same timing problem and wanted to know if the timing equipment did it or did the tech do something. thats about 400 bucks for just the equipment so i want to be sure that fixed it.
my other dyno is in the car somewhere with the torque graph. this is all i have on the comp at the time. no need to lie though. dc forum will vouch.
sorry to ***** the thread btw. still haven't heard anything back. im goin to the dealer tomarro..
You car is quick & powerful, no doubt. I was just a slight bit defensive when you mentioned derogatory comments re: A32B folk, such as Jime, as he is as quick & powerful you.
I apologize.
I apologize.
Quote:
I apologize.
It's fine, his car is slow Originally Posted by NmexMAX
You car is quick & powerful, no doubt. I was just a slight bit defensive when you mentioned derogatory comments re: A32B folk, such as Jime, as he is as quick & powerful you.I apologize.
Get that **** fixed.
Quote:
I apologize.
Jime? But that guy drives an automa-Originally Posted by NmexMAX
....ooohh.
went to the nissan dealer yesterday. apparently the Cipher program was wrong. my timing was at 15deg. in which i advanced it to 17. +1 Consult IIOriginally Posted by pmohr
Quote:
I apologize.
an apology? wow, i've never seen that from you. i have seen some of the ppl that you curk on. lol no need, it's all good. Originally Posted by NmexMAX
THe problem wasnt narrowed down really... i changed all the timing hardware and the car ran like a champ again. Pulled hard all the way to redline Etc...
I was supposed to get the EU installed and tunned 2 weeks ago but my transmission took a ****.
Last week i installed a HLSD 6speed trans from a 6th gena nd bought a spec stage 3 clutch .. everythign running me close to $1500. So this put me back 2-3 weeks from the tune.
The car even though pulls harder... its not as fast as B4. I use to be able to pull 2-3 cars on my buddies STI with I/E . This is B4 my cams...
We did a run and we were neck and neck.... i think tunning is to blame... since the cams my A/F has been all over the place... leaning out.. then riching etc...
I will report back when the car gets tunned with dyno sheets
Quote:
Cattman Gen III Headers|Cattman Catback|UDP|
Fidenza LW Flywheel|Spec Stg 2 Clutch|NWP Spacers|NWP SSIM plate|SSIM|P&P Manifolds|Twin Ignition System|Voltage Stabilizer|JWT S1 Cams,Springs,Retainers|ARP Head-Rod Bolts|3" MAF|Stack Custom CAI|TB Spacer|2.5 TestPipe|17" LightWeight SSR Comps|VIS CF Hood|ID CF Trunk & Wing|Tein SS Coilovers|Alutec FSTB|Progress RSB|Stillen Classic Lip Kit|
Shat load of mods you got there Cattman Gen III Headers|Cattman Catback|UDP|
same here, i dynoed without an afc and the car was lean in the low rpm and 12 afr from 4k onOriginally Posted by NiSmOVQ35
THe problem wasnt narrowed down really... i changed all the timing hardware and the car ran like a champ again. Pulled hard all the way to redline Etc...I was supposed to get the EU installed and tunned 2 weeks ago but my transmission took a ****.
Quote:
You dont know how bad i wanna dyno tune.... Now heres another thing that i think might throw me back a week or 2... ive heard talk that the A33B ECU is self learn. There are members who have TUnned there car Via EU and AFC's and after 2 months the car has gone back to factory settings... they say if i tune my car via the EU it was last only a while... and the only way to get rid of this is to drop in a TS ECU then tune... Originally Posted by NmexMAX
So...when shall we expect to get updated dynos from either of you with runfiles to go with them?
How true is this ? If so..... **** gatta give TS a call for a ECU.
You heard wrong, the A33B ECU is not selflearn for WOT (MAF) bursts, only the A34 +.Originally Posted by NiSmOVQ35
You dont know how bad i wanna dyno tune.... Now heres another thing that i think might throw me back a week or 2... ive heard talk that the A33B ECU is self learn. There are members who have TUnned there car Via EU and AFC's and after 2 months the car has gone back to factory settings... they say if i tune my car via the EU it was last only a while... and the only way to get rid of this is to drop in a TS ECU then tune... How true is this ? If so..... **** gatta give TS a call for a ECU.
You should be calling TS anyhow for an extended rev limit and altered CVTC map.
Quote:
I was confused at that as well.Originally Posted by sunstream453
but he has an EU, why would he need TS for revlimiter?
lol. im thinking he wanted to get a TS ECU so that he could lock in the WOT parameters for his A33B. im wondering how this myth about the a33b overriding WOT changes came about.
i know with an afc my car would some how void my tune. it would constantly adjust to the point i had to keep adding fuel. i use to have my settings at 0 and memorize my fuel setting and adjust them before a race for optimum performance. im currently gonna try the AEM FIC. not sure if any maxima's have tryed it. but it apparently works for the 350z..
there was something WRONG with either your car or your AFC then. ive been running the same numbers on my vafc2 for well over a year now and im still managing to be right where i want to be. either something was changing with your setup or your afc. you were probly coming up to a stuck injector or something along those lines
That theory came about from here:
http://forums.maxima.org/showthread.php?t=540911
And led to:
http://forums.maxima.org/showthread.php?t=555186
And led to:
Thanks for the info... i guess time to save up a little..
THey told me $300 to install the EManage Ultimate and like another $350ish to tune with raised rev limiter , gov taken off etc etc... Also looking forward to putting Meth injection on the car since i have a short ram sucking in hot air this should help cool down everything REAL NICE... Gimmi 2-3 weeks guys, ill have it all in and tuned with files and all.
ur gonna run rich as ***** with meth. if u wanna cool down the intake temps, get the spacers. if you already don't have it on that list of yours lol.
i do have the spacers.
Theres a N/A Altima SE-R running around here with Meth and he claims to have gained like 11whp on the dyno tunned with meth.... Hence i went ahead and decided to go with it as well... i guess ill try the EU install and tune for now, wait a little bit and then try out meth and see if that holds true.
I have lots o mods minus the meth injection and hope to at least break 255.
IMO, you can't claim NA if you're 'spraying C2H5OH (oh wait... that's Ethanol)...
Stop fronting. If you're into refilling bottles you might as well spray nitrous in there and get 1000000 x's the benefit.
Faggotry.
