Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Finally dynoed the car at higher boost, 431 hp/368 tq
Old Jan 24, 2009 | 07:34 PM
96sleeper's Avatar
I have been having some fuel system problems, so I wanted to dyno the car again and try to get the issues all sorted out. I think I figured out that the rising rate adjustable fpr is not rising anymore under boost so I will get that fixed. I was pretty rich in the middle and a little lean up top on this run.
I have seen over 12psi before from this pulley at the track, but today on the first two runs I was only getting a hair over 10 psi. For the last run I tightened the belt a little bit and saw 11 psi for this 3rd and final run.
Stock bottom end VQ35 with JDM knockoff cams and VQ30 timing equipment
V1 S-trim vortech with 2.70" pulley at 11psi for this dyno.
Intercooled, 3" charge piping, 3.5" CAI for S/C
Z32 MAF sensor, ported 70mm TB and hand ported IM
JWT ECU with S/C program and 100 octane timing map
deatschwerks 550cc injectors, walbro pump with boost-a-pump
adjustable fpr, SAFC for fine tuning
cattman headers
2.5" test pipe with electric cutout opened for dyno
2.5" exhaust with hooker muffler
fidanza flywheel/ACT XT pressure plate and street disc
Old Jan 24, 2009 | 08:01 PM
secondtonone317's Avatar
nycnissans
Nice numbers..........
Old Jan 24, 2009 | 08:12 PM
mtrai760's Avatar
'Trynna' is not a word
Old Jan 24, 2009 | 09:52 PM
QNO_A32's Avatar
amazing...mind posting some pics n stuff???
Old Jan 24, 2009 | 10:05 PM
maxina97's Avatar
wow! nice setup.
Old Jan 24, 2009 | 11:35 PM
Tatanko's Avatar
Bacon Lover
You need an emanage!
Great numbers nonetheless, though
Old Jan 25, 2009 | 12:15 AM
JonBlz's Avatar
a.k.a. STuNtMAN
very nice numbers keep up the amazing work
Old Jan 25, 2009 | 03:28 AM
po8pimp's Avatar
any vids of the dyno?? Also being a 6th gen owner, was wondering what the perks are by using the VQ30 Timing equipment vice the VQ35 Timing equipment?
Old Jan 25, 2009 | 07:29 AM
essential1's Avatar
My axles cry for mercy...
Nice numbers at 11lbs.
Using the vq30 timing equipment is not for power reasons. 4th and 5th gen guys with the VQ30 originally need to do this so that our original ECU can be retained with the swap.
for us to use VQ35 timing...
http://forums.maxima.org/all-motor/4...-progress.html
It would be a downgrade for you to "try" to use VQ30 timing.
Old Jan 25, 2009 | 06:45 PM
meximax's Avatar
SC Overspinning Swapper!!
Very nice number....and very comparable to mine.
Old Jan 26, 2009 | 01:36 AM
mastercater7's Avatar
VQ35 FTW
I am right there with ya'll and once I put my new gates belt on I will redyno, hopefully this week. Great numbers man! Were you running 100 octane fuel for this dyno pull?
Zack
Old Jan 26, 2009 | 04:10 AM
96sleeper's Avatar
Zack
No, 93 octane. I had JWT program my ecu for 100 octane because their normal boosted program is very weak on timing and doesn't make good power.
Old Jan 26, 2009 | 07:45 AM
Kevlo911's Avatar
Kevlo for President
Any dyno with the cutout closed?
Old Jan 26, 2009 | 08:07 AM
96sleeper's Avatar
I did that last time when I was on 6 lbs of boost and dynoed 366hp. I think it was around 20hp then off the top of my head. I was trying to get the fuel sorted out this time and didn't want to change any other variables.
Old Jan 26, 2009 | 09:09 AM
DandyMax's Avatar
3.5 in the works
Nice numbers Matt. I forget, are you running an SSIM or Z33 mani?
Old Jan 26, 2009 | 11:07 AM
96sleeper's Avatar
It is similar to a SSIM A33 manifold.
Old Jan 26, 2009 | 12:11 PM
ajcool2's Avatar
Vey nice numbers. Was your 11.6 at 12lb's of boost?
Old Jan 26, 2009 | 12:51 PM
96sleeper's Avatar
It was the same pulley and same setup, but I am not sure how much actual boost I saw on the run. It might have been less because I only trapped 120mph on the 11.6 pass, and previously had been almost 122mph.
Old Jan 26, 2009 | 04:50 PM
VQrebuild96's Avatar
Spray it and get into the 10's!
Idk though... your pretty much at the limit for a stock bottom end vq35de.
Do you think you can get any faster by building the bottom? Or will it just blow by all the gears after 500hp?
Old Jan 26, 2009 | 05:12 PM
96sleeper's Avatar
500hp in a fwd would be useless. I already have to stay on drag radials full time just to hook in 2nd gear (sometimes). 1st gear is useless except on slicks.
I can run faster than my 11.6 if I launch it hard like I used to when I was n/a, I just haven't been able to yet. It might not even hook with a hard launch. I have already reached the point where adding more power won't help anything. It has a few more tenths in it now.
Old Jan 26, 2009 | 07:12 PM
DonSupreme's Avatar
very nice numbers.
Old Jan 30, 2009 | 10:58 PM
AsthmaMax11's Avatar
awesome #'s matt. You must really love that car to have taken it this far. When are you going to the track next?
Old Jan 31, 2009 | 06:01 AM
96sleeper's Avatar
I have enjoyed the car, but I can feel the end drawing near. I will probably try to go to the track one more time this spring and give it one more chance.
Old Jan 31, 2009 | 07:55 PM
I'm hoping to get 4:10's and drag radials in the next few months so I might actually give you a good race this time. Just got a cam and tune so I am in need of some good races.
Old Feb 1, 2009 | 10:35 AM
4DRSpeed's Avatar
Project Ruby......
Good god!!
Old Feb 1, 2009 | 11:18 AM
accordingtou's Avatar
VQ30 DE T
Im impressed... As always.
Old Feb 3, 2009 | 10:48 AM
G4nismo's Avatar
very nice numbers! good job
Old Feb 3, 2009 | 11:02 AM
2theMaX05's Avatar
All I have to say is niceeeeeeeeeeeee...
Old Feb 9, 2009 | 04:50 PM
McSteve's Avatar
since you already dumped that much money in the car... just asking:
Would you be able to shave some time off the 1/4 mile if you were to get a quaife HLSD? Obviously i'm kind of a noob still, but wouldn't that help to put the power to the ground. From your mod list I couldn't see whether or not you had the AE tranny in it. Quaife probably isn't substantially better than the AE LSD.
Old Feb 9, 2009 | 04:56 PM
96sleeper's Avatar
I don't have the AE tranny, but I do have the factory VLSD unit. It works fine. I bet I would not be able to tell any difference with a quaife. I can already leave two black strips anytime I want to, and when I am on the slicks it hooks ok. Weight transfer is the biggest enemy of a fwd at the dragstrip and there is only so much you can do. I can shave some more off my time in the 1/4 mile from the launch though. I should be able to get back in the 1.7x 60ft range if I decide to launch it hard like I used to when I was n/a.
Old Feb 11, 2009 | 12:12 PM
99MAXPIMP's Avatar
nice numbers u should try 3'' all the wayback see if that helps
Old Feb 15, 2009 | 10:08 PM
95BLKMAX's Avatar
doesnt need it. he has a cutout and it was open for this dyno
Old Feb 26, 2009 | 09:59 AM
maxima92se's Avatar
OMG gives the impression that the 3.5 is a beast vs the 3.0... Good numbers none the less.
Old Feb 26, 2009 | 03:07 PM
acecars's Avatar
Impressive! How many miles do you get out of a clutch?
Lakersallday24
Jun 16, 2019 01:35 AM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
maxinout93
Aug 16, 2015 07:25 PM
acw
Aug 13, 2015 12:50 AM
