Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
01 Supercharged Merlot 328hp 305tq
Old Mar 31, 2012 | 03:08 PM
036mtmax's Avatar
I finally got the car running descent today and figured i would get it on the dyno mostly to check A/F's but was curious what it would do for numbers also. I am picking up the graphs Monday or Tuesday because the printer ran out of paper I did 3 pulls this one being the best of the three. Car only hit 7.5 psi on an 11 psi pulley so i think my next to do is chasing down a vacume leak and run it again. And it was on a Mustang Dyno.
Old Mar 31, 2012 | 03:19 PM
Rods03Max619's Avatar
Nice numbers, I forgot what it used to put down from the previous owner, I know you put some dough to get it running the way it was supposed to...
Old Mar 31, 2012 | 03:33 PM
036mtmax's Avatar
Previous owner put down 301 on a Dynojet but that's when it was an automatic. I def did hav to put some money into it but for once it runs awesome and im happy with it.
Old Mar 31, 2012 | 05:04 PM
ranmas2004's Avatar
NICE BRO!!! You got ES bushings in the motor mounts and subframes? That engine was shaking like crazy when he let up.
Old Apr 1, 2012 | 03:14 AM
036mtmax's Avatar
Lmao !! I know man i have had the ES subframe bushings sitting in my closet for a year but haven't put them in yet, After seeing the way the engine rocks on video im thinking that should be next.
Old Apr 1, 2012 | 05:23 AM
aic96max's Avatar
you have and adjustable fuel pressure regulator to compare the amount of boost on your gauge is showing to the amount of fuel psi youre getting? 328hp 305tq seems correct for 11 psi on a basic setup.. gauge maybe not reading right... 7 psi i dont think you would have seen 300 whp??? maybe??
Old Apr 1, 2012 | 06:41 AM
036mtmax's Avatar
aic i don't have an adustable fpr but my gauge in the car reads 7psi @ full boost. I had my friend plumb his auto meter gauge that he uses for dyno pulls into a different vacume source to confirm it during pulls. Both gauges read 13/14 warmed up on the vac side which is why i think there is a vac leak somewhere. I have seen 11psi before as well. I visually checked and smoke tested the IM and charge piping a couple months back and didn't find anything. I noticed the s/c belt is pretty loose but no squeeling at all or odd noises so it's got me stumped.
Old Apr 1, 2012 | 08:08 AM
aic96max's Avatar
yeah something definitely doesnt add up.. try a nother vac source , i had the same deal on my car, gauge was showing 15 psi when the car was running 20+ -_- but the numbers dont lie, maybe im wrong but 320+ whp on 7 psi blower setup in a 3.0 doesnt seem correct..
Old Apr 1, 2012 | 09:19 AM
036mtmax's Avatar
I know that's weird, It doesn't seem to be slouching at all so idk. Where would you recommend tapping into ??
Old Apr 1, 2012 | 09:58 AM
aic96max's Avatar
somewhere right off the intake, not too divided already, maybe even tap and tread 1/8 npt an entirely fresh source off the intake, but that shouldnt be necessary
Old Apr 3, 2012 | 04:35 PM
036mtmax's Avatar
This was the best i could come up with for now. This was one of the runs where you can see boost,timing and a/f's. You can see later in the pull where boost starts to drop off after 5500.
Old Apr 3, 2012 | 05:30 PM
OC_Nooby's Avatar
I hit 345 whp and 295 tq at 13.4psi. So if you did that at 7psi, my god it would be an animal at 11psi
Old Apr 3, 2012 | 05:53 PM
036mtmax's Avatar
It really has me baffled though. Either way im happy with the numbers, I guessed 320 ish so i was right there.
Old Apr 3, 2012 | 06:59 PM
nismomaxct's Avatar
Nice numbers. When I only got a text from you after the first pull and then nothing else, I thought you were too heartbroken to let me know your final number. lol.
Old Apr 4, 2012 | 12:40 AM
TurboA32's Avatar
Why is your boost dropping off? It should be rising with the rpm and you should have peak HP at the redline with a 00VI
Old Apr 4, 2012 | 02:32 PM
036mtmax's Avatar
I think it drops a pound or so after 5500 because the belt is slipping as it is pretty loose and i just haven't gotten around to snugging it up, But the three or more pounds before 5500 im loosing i have no idea. Checked vacume lines via smoke test and visual and came up short. Both the gauge in the car and on the dyno confirm 7 psi and then a drop off. Both also register 12/13 @ idle so i have no idea what's going on.
Old Apr 5, 2012 | 06:33 PM
s1mply_v's Avatar
I'd take that all day too. 328whp and 305wtq at only 7psi, it'd be around 375whp at 11psi
When I dyno'd it on a legit Dynojet way back when it was an automatic, it only pulled 301whp and 250wtq because the torque converter and clutches in the auto trans was smoked. They called it the torqueless wonder because of that dyno
Old Apr 8, 2012 | 07:20 PM
036mtmax's Avatar
I'm Happy with the numbers but i almost feel there right for that setup even though two gauges confirmed 6.5psi @ redline so idk. Both also read 12/13 on vac side @ idle which is low so who knows. The belt is kind of loose so ill snug that first and then try a boost leak test. If it pulled anywhere close to 375 id ****..
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Cumalot
Nov 28, 2000 09:38 AM
TommyBoiSxty9
Sep 13, 2000 08:16 PM
