Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
*125 000 KMS, still running on original auto Tranny fluid! What to do!*
Old Oct 1, 2003 | 09:50 PM
OpTikOl's Avatar
Hey guys,
I'm hesitating changning my transmission fluid because so far 3 mechanics told me not to since it was never changed before and they said the tranny could start slipping. This worries me. Right now it's dark brown in color. Do i change it or not? Thanks
Old Oct 1, 2003 | 11:29 PM
UncleMax98's Avatar
How about a drain and fill? That would put in about 4 quarts of fresh ATF. Keep the old stuff, though. If the transmission slips, you can put the old stuff back in (and start saving money for a new one). If no problem, do another drain and fill after 5 000 KMS or so.
Old Oct 2, 2003 | 07:41 AM
Cutler's Avatar
Originally Posted by OpTikOl
Hey guys,
Drain and fill it, not flush it... Your Mechanic should not say no change, he should say no flush....
Old Oct 2, 2003 | 12:57 PM
iwannabmw's Avatar
If you do nothing, you are guaranteed to have a problem and a very expensive repair. The drain and fill is the best way to go. If it starts slipping because of that, you were on borrowed time anyway.
Old Oct 3, 2003 | 09:30 AM
NewbieNissan's Avatar
Mine is 2 80000 + miles, is it advisable to do a flush at this point or is the drain and fill a better method.
Old Oct 5, 2003 | 01:59 AM
limsandy's Avatar
When did you last change the tranny fluid? If you never changed yours for 80k miles, then drain and refill.
~limsandy
Old Oct 5, 2003 | 07:47 AM
OpTikOl's Avatar
~limsandy
When you say Drain and fill, you mean just let out a little bit of fluid and put a little bit of fresh fluid back in rather than dump the whole thing and replace it all? how much of it should i drain?
Old Oct 5, 2003 | 05:36 PM
UncleMax98's Avatar
Drain and fill is when you open the drain plug at the bottom (middle of pan) and let the AFT drains out, typically about 4 Qt. If you wait about 30 minutes, up to 5 1/2 Qt. may come out. That's about 1/2 of the system capacity.
Old Oct 5, 2003 | 05:46 PM
twiggy144's Avatar
Would changing approx 1/2 of the ATF using this method be considered less risky than power flushing all the fluid out ( disconnecting the cooler return line, install a bleeder line into a can, starting engine for a few seconds, tooping up the fluid with fresh one) , considering the atf might have never been serviced at 60000 milles?
alixc
Aug 11, 2020 01:48 PM
Ray229Harris
Sep 16, 2015 08:16 PM
homeyclaus
Sep 3, 2015 06:15 PM
mclasser
Aug 23, 2015 09:32 PM
