Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Oil Change Intervals: By Time
Old Dec 22, 2003 | 10:41 PM
RainMeister's Avatar
Nissan's recommendation for oil change is the earlier of 3 months or 3,750 miles. I usually average less than 7,500 miles a year, so that I've typically changed the oil every 6 months for most of my cars. How important is it to stick to the 3 month interval? Does oil degrade that quickly? I've searched through other threads, but most only seem to address mileage between oil changes. TIA.
Old Dec 23, 2003 | 02:08 AM
limsandy's Avatar
I'd recommend using Amsoil or Mobil1 5W-30 synthetic oil. That way, you know you're using top quality oil and it won't degrade quickly. You never really know what Nissan dealers put into your oil tank. I use Amsoil.
~limsandy
Old Dec 23, 2003 | 05:53 AM
knapp9's Avatar
I'd offer the opinion that your 6 month interval is perfectly okay. Oil doesn't degrade quickly. It picks up combustion blowby gasses and insolubles, and with that low of mileage, probably does not get up to proper operating temp often enough. That is harder on the oil than simple age, and why you want to eventually change the oil on the basis of time rather than mileage. 6 months is probably okay. Heck, even long duration oils like Amsoil suggest changing within a 1 year period if the stated mileage isn't reached first.
Old Dec 23, 2003 | 06:57 AM
Jatan's Avatar
You should be fine doing the oil change twice a year, but if you're worried about it, do it 3 times a year It only takes about 5-10 minutes to do it anyways
Old Dec 23, 2003 | 09:08 PM
outsider's Avatar
lol do what i do every 1800-2000 miles oil change
with good old castrol 5-30 oil
Old Dec 24, 2003 | 10:02 AM
iwannabmw's Avatar
As long as the trips aren't a mile or 2 in cold weather, you're probably okay. If they are, I'd probably go with the 3 month interval or a high quality synthetic instead.
Old Dec 24, 2003 | 10:11 AM
Mick Max's Avatar
Wild at Hurt
iwannabmw is right.
Short trips especially in the cold dilute the oil because a richer mixture is leaking past the rings. And shorter trips dont allow for the fuel in the oil to cook off.
Old Dec 29, 2003 | 02:36 PM
gfcrane's Avatar
I had the same problem. Changing at 3 month intervals resulted in only 800 miles and I thought this was a bit much. I now change every six months but switched to synthetic oil. (Castrol 0W30-the made in Germany ones only)
Old Dec 29, 2003 | 05:55 PM
trey
i also do 5-6 month oil changes even in the cold chicago winters. I only put on about 500 miles a month and i do many short trips. Hope i'm ok ahha
Old Dec 30, 2003 | 04:50 PM
pruizgarcia's Avatar
That GC 0w30 is some good stuff and sometimes hard to fine. How is it doing in your Max? Will be switching to Amsoil after my rinsing phase of Auto-RX. Tempted into trying the GC 0w30.
Pedro
Old Jan 1, 2004 | 02:25 PM
gfcrane's Avatar
Pedro
I'm due to change the GC in early March and will do a UOA then. Posting here is a bit of a drag, but I do post on BITOG.
MatthewsMaxima
Sep 11, 2015 03:21 AM
maxinout93
Aug 20, 2015 02:17 AM
Maxgig
Aug 18, 2015 09:17 PM
RealityCheck
Aug 5, 2015 06:18 AM
